Discuss
leaking maytag washer
 in
Washer Repair
Older Maytag washer leaks from the left side while the water is filling the tank. Are there any hoses going
Appliance Repair Forum > Appliance Repair Help > Washer Repair » leaking maytag washer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-26-2007, 09:43 AM
rboyd rboyd is offline
Junior Member
rboyd is on a distinguished road
Default leaking maytag washer
Brand: -brand-   Age: 5 - 10 years
Older Maytag washer leaks from the left side while the water is filling the tank. Are there any hoses going to the top of the tank and how do you open the washer to check for loose hoses?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 09:57 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi rboyd
In order to provide the most accurate advise I need the complete model number of your washer. You can find it on top of the control panel.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 11-09-2007, 04:54 PM
wonderwomanbee@msn.com wonderwomanbee@msn.com is offline
Junior Member
wonderwomanbee@msn.com is on a distinguished road
Default Maytag washer small water leak when draining
MODEL LAT9593AAL
Facing the washer, the small leak is coming from right front corner. I had a GE washer that did this once. However, it was a large leak. The repair said it was off balance. He adjusted the legs and it work ok. Could this be the same case. Do I just maybe need to adjust the legs/or tub could be off balance?
Wonderwomanbee
  #4 (permalink)
Old 11-09-2007, 06:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Wonderwomanbee
Remove the front panel and you will see exactly where the water coming from. Then replace the leaking part and enjoy.
- Here are the break down diagrams for the Maytag washer Model LAT9593AAL
Good luck.
__________________
  #5 (permalink)
Old 11-09-2007, 08:39 PM
Junior Member
Gene,
Thanks for your help. I took the front panel off and the leak is at the base of the tub. So it looks like, I would need a mounting stem & boot seal. I was hoping to repair it myself. It looks like some work to take it apart. I am not sure where to start.
Is it easy to replace or with no experience would it be wiser for me to call a repair man. I also see the part is not cheap. Give me some feedback.
Thanks, Wonderwomanbee
  #6 (permalink)
Old 11-11-2007, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Wonderwomanbee
Yes, you were right.
In such situation the mounting stem and boot seal has to be replaced.
I can not say this is a very simple job, but with a basic knowledge how to use a hand tools you can do it.
You have to have:
1. The spanner wrench - part number AP3538707
2. A set of socket wrenches
3. A set of hex keys
4. A 1/4' nut driver
5. A hummer
You can find the complete instructions how to replace the mounting stem and boot seal on page 3-35 in the service manual.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Leaking rjenkins7 Washer Repair 6 06-08-2008 03:49 PM
leaking washer Michelle Washer Repair 3 10-20-2007 05:44 AM
leaking washer rocco Washer Repair 2 10-13-2007 11:57 AM
leaking washer jeanne Washer Repair 0 08-14-2007 05:09 PM
Maytag Washer Bottom of tub leaking at seal David S Washer Repair 4 08-10-2007 11:16 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
