Discuss
Noise/Knocking Only During Spin
 in
Washer Repair
I am having trouble with my washer. During the spin cycle it makes a loud knocking sound that gets worse
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Noise/Knocking Only During Spin
  #1 (permalink)
Old 03-23-2011, 08:41 PM
Junior Member
awilliams4743 is on a distinguished road
Default Noise/Knocking Only During Spin
Model Number: LSR8300EQ1   Brand: Whirlpool   Age: More than 10 years
I am having trouble with my washer. During the spin cycle it makes a loud knocking sound that gets worse the longer it runs. While watching the spin cycle with the cover off, I have also noticed that the agitator doesn't always spin freely with the clothes. It appears like it is briefly getting snagged on something every so often. Similar to the noise, the frequency of this snagging seems to increase the longer I let the spin cycle run. I am guessing the cause of my problem is the gear box. Am I on the right track and is there anyway to determine for sure if it is the gear box other than to just replace it? Thanks.
Ads By Google
Related Models
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
 LSU090HE Air Conditioner
 LSU092CE Air Conditioner
 LSU092HE Air Conditioner
 LSU120HE Air Conditioner
 LSU122CE Air Conditioner
 LSU122HE Air Conditioner
 LSU180HE Air Conditioner
 LSU182CE Air Conditioner
 LSU182HE Air Conditioner
 LSU240HE Air Conditioner
 LSU242CE Air Conditioner
 LSU242HE Air Conditioner
 LSUC121PMA Air Conditioner
 LSUJ0910CL Air Conditioner
 LSUK1830CL Air Conditioner
 LSUK1830HL Air Conditioner
 LSUK2430CL Air Conditioner
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
  #2 (permalink)
Old 03-25-2011, 12:06 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Take off the cabinet and operate it by by-passing the lid switch and watch to see if you can determine if there is a problem in the springs or support pieces.
If not check the brakes using the info in the Sticky at the top of this page by Richappy on Direct Drive Brakes.
__________________
  #3 (permalink)
Old 03-25-2011, 05:23 PM
Junior Member
Default
Thanks sidfink. I checked all the springs and support pieces and didn't see anything that looked broken.
I also pulled off the motor and pump as suggested in the Direct Drive Brakes Sticky. The coupler pieces all look OK. When I rotate the coupler clockwise the basket seems to rotate OK. The interesting thing is that while I was spinning the basket the agitator moved in one direction and then the other like it was trying to agitate. Is this normal? Thanks.
  #4 (permalink)
Old 03-26-2011, 05:38 PM
Junior Member
Default
Replaced the gear box today and the washer is working great.
  #5 (permalink)
Old 03-26-2011, 05:49 PM
Senior Expert
APP Volunteer
Default
Well great, those transmissions usually are pretty solid, but sometimes they do fail.
Glad you got it going and thanks for updating us.
__________________
  #6 (permalink)
Old 04-02-2011, 06:17 AM
Junior Member
Default
I may have celebrated too early. After the using the washing machine for a week it now it started emitting a burnt rubber smell yesterday. The machine still seems to be running fine. I pulled it all apart again last night and didn't see anything that looked bad, so I put it back together and am running it more today to see if the problem either becomes more obvious or goes away. Any ideas on what this could be? Thanks.
  #7 (permalink)
Old 04-02-2011, 04:28 PM
Senior Expert
APP Volunteer
Default
Sometimes you can jam the coupling in when replacing it, so if the problem continues check that out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Knocking noise on spin cycle homealone Washer Repair 4 02-21-2011 01:45 AM
Ice Maker not working. Knocking noise bwilson029 Refrigerator & Freezer Repair 0 10-28-2010 07:54 PM
GE Knocking Noise on Final Spin and Lights Flicker Swarms Washer Repair 2 06-24-2010 05:11 AM
Knocking noise just before compressor shuts off wmitch21 Refrigerator & Freezer Repair 1 03-27-2009 04:46 PM
knocking noise when getting ready to spin judith g Washer Repair 3 10-16-2008 04:34 PM
