Spins better with smaller loads, but clothes are not coming out as dry as they used to. Thanks
You probably have a bad clutch(AP3094537). It's possible it just wore out. Remove the motor and pump and turn the tranny coupler clockwise, if the clutch housing above the tranny turns but not the spin basket, that confirms it. Replace the clutch, and repeat the coupler test, if hard to turn, you also have bad brake shoes.
