bill dof
#1 Posted : Wednesday, March 23, 2011 12:51:17 PM(UTC)
bill dof
What is the best method to remove and replace spring and cable for drain boot
Joe / APP Team
#2 Posted : Wednesday, March 23, 2011 1:23:07 PM(UTC)
Joe / APP Team
Bill,
Here are the instructions for the door boot installation from the service manual.
I use a long bladed awl or ice pick and a pair of needle nose pliers, to carefully stretch and align the spring into the metal wire clamp opening.
Good Luck
1. Align the door boot with the D-shape toward
the front, with the flat of the D toward
the bottom. Also, locate the large
tab toward the top center of the shroud.
2. Stretch the rear lip of the door boot onto
the tub cover.
3. Move the rear door boot lip along the face
of the tub cover until the locator notches
in the door boot align with the locator ribs
in the tub cover. Check alignment of the
six rib marks and reposition if necessary.
This is necessary in order to have the locking
tabs on the inside perimeter of the door
boot align with the corresponding tabs on
the front shroud.
4. Carefully loop the wire loop with spring
around the lip of the outer tub cover and
place the spring at the 11:00 o'clock position,
just left of the top rib of the outer tub
cover. Hook the end of the spring over the
nearest tub cover clip to hold the spring
and wire in position for final hookup to the
other end of the wire loop.
5. Using either the hold down bracket or the
outer tub spring, grasp the hook end of
the spring and apply pressure on the
clamp wire into the door boot.
6. Pull the spring hook toward the wire loop
to engage the spring with the wire loop.
NOTE: Be careful not to bend or crease the
wire loop. If the wire loop becomes bent, the
result will be a potential leak upon replacement
of the boot seal onto the outer tub
cover.
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag LA882 Washer (Dishwasher Repair)
by soloRepairer 3/30/2024 2:12:38 PM(UTC)
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Amanda washer intermittently wont fill (Washer Repair)
by Guest 3/13/2024 3:48:07 PM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
