| » Cabrio washer code "OL" |
Quote:
<a href="http://www.aussiewhitegoodsrescue.com.au/"> Appliance Spare parts,Appliance Repairs</a> |
Quote:
You have checked and made sure you have good water supply and pressure to the fill valve, from the faucets, and a valve solenoid is not "sticking" open, a quick easy check, unplug the power cord, while the washer is filling in a warm water wash.The valve should "snap" shut. We're not aware of a need to "reprogram" a new CCU/control board, when replaced. But you can test and recalibrate the water level transducer, if needed, but that's not a normal occurrence either. You have checked and made sure there are no twists, kinks, holes or loose air dome hose connections, correct. ? You also want to disconnect the air tube from the tub and check the tub connector for deposits and debris, restricting the air flow into and up the tube. and make sure the retainer clip and screw are not too tight or pinching the tube. Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Thanks,
__________________
awesome thanks for the quick reply!
for anyone's reference in the future...I had f41 and f51 fault codes, running diag check failed on c1 with an oL fail code. f41 and f51 indicated an rps sensor problem, further investigation found that the basket was stuck in the up most position, followed the manual to disassemble as I was sure the basket being stuck was causing the rps sensor to err out during a normal wash cycle. also note I had no agitation during a normal cycle. once basket was loosened enough to remove the obvious fault was corrosion on the drive shaft. cleaned and now she works perfect all thanks to allot of info I found here. cheers and hope my experience helps someone! |
Quote:
You're Welcome and Thank You for your update / report. It should be very helpful to those who have a similar issue, once they find their way to the Repair Forum. Thanks Again,
__________________
I had a oL error code (overload code) on my Whirlpool Cabrio. The basket (drum) was not floating up to disengage from the shaft when it was supposed to. The basket should be able to slide up and down independently of the agitator about 1/2 inch when lifted. I was able to remove the agitator as shown here http://www.youtube.com/watch?v=D2mxOA-taoo with little effort. But when I tried to pull the basket up and off the shaft it wouldn't budge. I was able to free it by lifting the basket up with one hand while pounding on the end of the shaft with a 3 foot long 4x4. I found that the shaft had rusted to the basket. I sanded up the shaft. Now it works perfectly with no oL code.... until it rusts again someday on that nicely sanded shaft.
Quote:
Everyone here on the Forum appreciates the updates and service Information and experiences. No repair is exactly the same, evry little bit helps. Thanks Again
__________________
| Display Modes | |
| Whirlpool Cabrio "Long Drain" problem | JeffreyF | Washer Repair | 18 | 03-30-2013 03:59 PM |
| Samsung Washer "OE" error code | rfgriffin | Washer Repair | 4 | 09-20-2011 08:12 PM |
| Whirlpool Washer "FH" error code | johnvb | Washer Repair | 0 | 11-21-2010 09:55 AM |
| neptune front load washer gives "LR" code on display panel | jacapp30 | Washer Repair | 1 | 09-13-2010 05:11 PM |
| Cabrio keeps popping up with "oL" code, even when it's not | CopaDave | Washer Repair | 1 | 11-24-2009 06:35 PM |
