| » Error Code F27 |
Model Number: WFW8300SW04 Brand: Whirlpool Age: 1 - 5 years
For the past several months the washer would randomly indicate F20 error code - you could press cancel and the start cycle and it would complete full cycle. The issue became worse until it was very difficult to get a full cycle completed. Cleaned drains and replaced pressure switch and now get F27 error code. Washer will sometimes complete a full cycle but rarely....what now?
Quote:
Wilson, Both of the codes you mentioned are indications of a water level problem. You've replaced the water level switch, but check and make sure the connector on the new switch, and the harness to the CCU(main control board), did not get knocked loose during the repair. Remove the air hose from the water level switch, and blow into the hose,as hard as possible, to clear any debris that may have accumulated in the hose. Remove the lower panel, and remove the filter from the drain pump and check and clear any debris from the filter and the interior of the pump, and hoses. You may want to remove the hoses from the faucet and fill valve, and clean any sediment from the filter screens from both components, and also flush the faucets for a minute or two, to clear debris in the water supply pipes. I'm pretty sure you'll be fine after these checks,repairs. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Error Code E5e | GILWHO | Washer Repair | 1 | 02-01-2011 06:16 PM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| Error code F2-E9 | Craig Hughes | Oven Repair (including Ranges and Cooktops) | 1 | 10-02-2009 09:32 PM |
| Error code FC | egri08 | Oven Repair (including Ranges and Cooktops) | 0 | 06-09-2008 09:31 AM |
| FC error code | Bassoonman | Oven Repair (including Ranges and Cooktops) | 1 | 05-07-2008 03:14 PM |
