Discuss
maytag A 5000 washer fills wont agitate
 in
Washer Repair
Mr. Gene, The transmission pulley will turn both ways. It will do this whether the belts are on or if
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag A 5000 washer fills wont agitate
  #31 (permalink)
Old 03-28-2013, 06:39 PM
Member
jesus freak is on a distinguished road
Default
Mr. Gene, The transmission pulley will turn both ways. It will do this whether the belts are on or if they are off.
What I was trying to explain earlier was a test someone told me to try. They said to start the washer on the agitation cycle and see if creating more belt tension by holding the motor will get the transmission turning. When I did that the transmission would barely turn and the belt did a lot of squeaking. When I gave it more tension the motor would stop turning.
  #32 (permalink)
Old 03-28-2013, 07:20 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The transmission housing isn't supposed to rotate during agitation. It is prevented from turning by the brake. Only the input shaft turns and the output shaft rotates back and forth for agitation. These shafts are within the transmission housing. You say you can rotate the pulley CCW (viewed from below) continuously? When you do this by hand, does the agitator agitate? If not, check the stop lug on the bottom of the pulley. It is screwed to and splined to the transmission input shaft. The drive lug on the pulley engages the stop lug and forces the input shaft to rotate. If the stop lug is rotating but the transmission input shaft is not, then the splines are stripped. If the input shaft is rotating but the agitator is not moving then the transmission is bad.
Eric
  #33 (permalink)
Old 03-29-2013, 09:21 AM
Member
Default
The splines must be stripped. The drive lug on the pulley is rotating the stop lug on the shaft, but there is no rotation of the shaft. If I rotate the pulley CW, there is full rotation of shaft and the transmission. Then if I rotate it CCW, everything rotates initially, and then only the pulley rotates. I hope that helps. Where do I go from here?
  #34 (permalink)
Old 03-29-2013, 01:28 PM
Expert
APP Volunteer
Default
Have you checked to see if something is jammed under the agitator? If there is nothing there, I think you have a bad transmission. Take the screw out of the bottom of the shaft and remove the stop lug to check the splines. They are not very deep. Remove the pulley by rotating it CCW until it comes off. Place the stop lug back over the shaft and try to rotate it either way. If it won't turn the input shaft, something is jamming it. Either a bad transmission or jammed agitator. The transmission is repairable and parts are available but doing the repair depends on your mechanical skills and abilities.
Eric
  #35 (permalink)
Old 03-29-2013, 08:49 PM
Member
Default
Eric & Gene,
Thanks for your help. My wife is now the happy owner of a Maytag MVWC350AW.
  #36 (permalink)
Old 03-30-2013, 05:41 AM
Expert
APP Volunteer
Default
I hope it works out for you but that is a Whirlpool vertical modular washer design and is a real piece of junk in my opinion and most any tech that has worked on them as well as the many consumers that have had problems with them. They are everywhere being sold under various name brands and model numbers. There is no Maytag company, it's just a name. That washer design has been out for 3 years now and there have been many problems with it. Maybe, and hopefully, you will get many years of trouble free operation out of it. Just wanted to let you know. The only decent top loader nowadays are the Speed Queens but they run around $800.
Eric
  #37 (permalink)
Old 03-30-2013, 07:32 AM
Member
Default
I knew I should have consulted you guys first. Any more suggestions? This thing is a little noisy! I don't mind spending money on quality equipment.
  #38 (permalink)
Old 03-30-2013, 08:09 AM
Expert
APP Volunteer
Default
Speed Queen AWN542, AWN432, AWN412. Quality built, good customer support.
Eric
  #39 (permalink)
Old 03-30-2013, 08:10 AM
Member
Default
Where can I find these?
  #40 (permalink)
Old 03-30-2013, 08:23 AM
Expert
APP Volunteer
Default
Speedqueen.com: Home Laundry - Dealer Locator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer fills but wont start toyes Washer Repair 5 11-21-2009 07:54 PM
Maytag commercial washer wont agitate techman20 Washer Repair 2 10-27-2009 10:22 AM
f 01 code on maytag 5000 series washer hurd Washer Repair 1 09-09-2009 03:22 PM
Maytag washer fills but doesn't agitate Relztrah Washer Repair 1 06-25-2009 07:04 AM
my estate washer only fills up but wont agitate rinse or spin redbacks12 Washer Repair 0 08-03-2008 09:15 PM
