Motor spins, not belt during initial rinse
Model Number: FWXB23RGS0 Brand: Frigidaire Age: More than 10 years
Frigidaire Crown Series washer fills, agitates, drains, then spins the dirty water fine. There is the time at the start of the rinse when it starts adding the rinse water, the motor rod is spinning and the part that is connected to the rod that the belt goes around is spinning but the belt is not turning.
After the tub fills with rinse water the agitation works, drains fine, and the final spin work.
Is there a time at the start of the rinse cycle when rinse water is added and the motor spins the belt and tub for a bit before it stops spinning and fills with rinse water?
Is there a pin or something in the motor that may be missing or broken?
Frigidaire Crown Series model FWXB23RGS0 2000 model year.
Everything else seems to be working, though old, except for this part of the process.
Thank you
Ads By Google
Related ModelsFrigidaire FWXB23RGS0 Frg(v0) / Washer Frigidaire FWXB45RGS0 Washer - Frig/best Buy Frigidaire FWXB45RGS1 Washer - Frig/best Buy Frigidaire FWY833KAS0 Frigidaire/washer Frigidaire FWY833KCS0 Frigidaire/washer Maytag G Range - S/c F/s Gas Hardwick G-433 Surface Unit - Ele Hardwick G-436 Surface Unit - Ele Hardwick G-445 Surface Unit - Ele Jenn-Air G0206B-8 Electric Grill Outdoor Jenn-Air G100 Surface Unit - Ddraft Ele Jenn-Air G101 Surface Unit - Ddraft Ele Jenn-Air G102 Surface Unit - Ddraft Ele Jenn-Air G103 Surface Unit - Ddraft Ele International G1110PRA Range - F/s Std Gas International G1110PRW Range - F/s Std Gas Frigidaire G12W Frigidaire G15W Frigidaire G18W Frigidaire G21CL0 Frg(v1) / Gas Range Frigidaire G21CW0 Frg(v2) / Gas Range Frigidaire G21CW2 Frg(v1) / Gas Range Frigidaire G21CW3 Frg(v2) / Gas Range Frigidaire G21PCL0 Frg(v1) / Gas Range Frigidaire G21PCL1 Frg(v3) / Gas Range Frigidaire G21PCL3 Frg(v2) / Gas Range Frigidaire G21PCL4 Frg(v2) / Gas Range Frigidaire G21PCL5 Frg(v4) / Gas Range Frigidaire G21PCW0 Frg(v2) / Gas Range Frigidaire G21PCW1 Frg(v4) / Gas Range Frigidaire G21PCW3 Frg(v1) / Gas Range Frigidaire G21PCW4 Frg(v1) / Gas Range Frigidaire G21PCW5 Frg(v3) / Gas Range Frigidaire G22W Frigidaire G24CL0 Frg(v1) / Free Standing Gas Range Frigidaire G24CL3 Frg(v2) / Gas Range Frigidaire G24CL4 Frg(v4) / Gas Range Frigidaire G24CW0 Frg(v2) / Free Standing Gas Range Frigidaire G24CW3 Frg(v1) / Gas Range Frigidaire G24CW4 Frg(v3) / Gas Range Frigidaire G24PCL0 Frg(v3) / Gas Range Frigidaire G24PCL1 Frg(v5) / Gas Range Frigidaire G24PCL3 Frg(v2) / Gas Range Frigidaire G24PCL4 Frg(v4) / Gas Range Frigidaire G24PCW0 Frg(v4) / Gas Range Frigidaire G24PCW1 Frg(v6) / Gas Range Frigidaire G24PCW3 Frg(v1) / Gas Range Frigidaire G24PCW4 Frg(v3) / Gas Range Frigidaire G25BNL0 Frg(v2) / Gas Range Frigidaire G25BNW0 Frg(v1) / Gas Range Frigidaire G30BCL2 Frg(v2) / Gas Range Frigidaire G30BCW1 Frg(v1) / Gas Range Frigidaire G30CL0 Frg(v5) / Gas Range Frigidaire G30CL2 Frg(v2) / Gas Range Frigidaire G30CL3 Frg(v4) / Gas Range Frigidaire G30CW0 Frg(v6) / Gas Range Frigidaire G30CW2 Frg(v1) / Gas Range Frigidaire G30CW3 Frg(v3) / Gas Range Frigidaire G30LPNL1 Frg(v2) / Gas Range Frigidaire G30LPNL2 Frg(v2) / Gas Range Frigidaire G30LPNL3 Frg(v2) / Gas Range Frigidaire G30LPNW1 Frg(v1) / Gas Range Frigidaire G30LPNW2 Frg(v1) / Gas Range Frigidaire G30LPNW3 Frg(v1) / Gas Range Frigidaire G30NL1 Frg(v1) / Gas Range Frigidaire G30NL2 Frg(v2) / Gas Range Frigidaire G30NL3 Frg(v3) / Gas Range Frigidaire G30NL4 Frg(v4) / Gas Range Frigidaire G30NL5 Frg(v2) / Gas Range Frigidaire G30NL6 Frg(v2) / Gas Range Frigidaire G30NL7 Frg(v4) / Gas Range Frigidaire G30NW1 Frg(v5) / Gas Range Frigidaire G30NW2 Frg(v6) / Gas Range Frigidaire G30NW3 Frg(v7) / Gas Range Frigidaire G30NW4 Frg(v8) / Gas Range Frigidaire G30NW5 Frg(v1) / Gas Range Frigidaire G30NW6 Frg(v1) / Gas Range Frigidaire G30NW7 Frg(v3) / Gas Range Frigidaire G30PCL0 Frg(v7) / Gas Range Frigidaire G30PCL1 Frg(v7) / Gas Range Frigidaire G30PCL3 Frg(v2) / Gas Range Frigidaire G30PCW0 Frg(v8) / Gas Range Frigidaire G30PCW1 Frg(v8) / Gas Range Frigidaire G30PCW3 Frg(v1) / Gas Range Frigidaire G30PNL1 Frg(v2) / Gas Range Frigidaire G30PNL2 Frg(v2) / Gas Range Frigidaire G30PNL3 Frg(v4) / Gas Range Frigidaire G30PNL4 Frg(v6) / Gas Range Frigidaire G30PNL6 Frg(v2) / Gas Range Frigidaire G30PNL7 Frg(v2) / Gas Range Frigidaire G30PNW1 Frg(v1) / Gas Range Frigidaire G30PNW2 Frg(v1) / Gas Range Frigidaire G30PNW3 Frg(v3) / Gas Range Frigidaire G30PNW4 Frg(v5) / Gas Range Frigidaire G30PNW6 Frg(v1) / Gas Range Frigidaire G30PNW7 Frg(v1) / Gas Range International G3110PRA-M Range - F/s Std Gas International G3110PRA5K Range - F/s Std Gas International G3110PRW-M Range - F/s Std Gas International G3110PRW5K Range - F/s Std Gas International G3127WRA Range - F/s Std Gas International G3127WRA-3 Range - F/s Std Gas International G3127WRA-4 Range - F/s Std Gas International G3127WRA-5 Range - F/s Std Gas International G3127WRV Range - F/s Std Gas International G3127WRV-3 Range - F/s Std Gas International G3127WRV-4 Range - F/s Std Gas International G3127WRW-3 Range - F/s Std Gas International G3127WRW-4 Range - F/s Std Gas International G3127WRW-5 Range - F/s Std Gas International G3127XRA-5 Range - F/s Std Gas International G3127XRW-5 Range - F/s Std Gas Frigidaire G31BFH0 Frg(v3) / Gas Range Frigidaire G31BFH1 Frg(v6) / Gas Range Frigidaire G31BFL0 Frg(v2) / Gas Range Frigidaire G31BFL1 Frg(v5) / Gas Range Frigidaire G31BFW0 Frg(v1) / Gas Range Frigidaire G31BFW1 Frg(v4) / Gas Range Frigidaire G31BPNL1 Frg(v2) / Gas Range Frigidaire G31BPNL2 Frg(v4) / Gas Range
