Discuss
Agitator Won't Turn Manually?
 in
Washer Repair
If I Can't Move The Agitator By Hand, What Causes This? This Is The Same Washer That Agitates Just
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator Won't Turn Manually?
  #1 (permalink)
Old 07-27-2007, 05:03 PM
CAN I DO IT CAN I DO IT is offline
Junior Member
CAN I DO IT is on a distinguished road
Question Agitator Won't Turn Manually?
Model Number: 11092429800   Brand: Kenmore   Age: More than 10 years
If I Can't Move The Agitator By Hand, What Causes This? This Is The Same Washer That Agitates Just Fine, But When Advances To Spin/drain Cycle It Stops And There's No Sound At All. It Does This On All Cycles(reg., Perma-a-press, Gentle). Any Info. Will Be Much Appreciated!
Related Models
Kenmore 11092572100 WASHER
Kenmore 11092572800 WASHER
Kenmore 11092573010 WASHER
Kenmore 11092573110 AUTOMATIC WASHER
Kenmore 11092573810 AUTOMATIC WASHER
Kenmore 11092573910 WASHER
Kenmore 11092580000 AUTOMATIC WASHER
Kenmore 11092580900 AUTOMATIC WASHER
Kenmore 11092581120 AUTOMATIC WASHER
Kenmore 11092581220 AUTOMATIC WASHER
Kenmore 11092581420 AUTOMATIC WASHER
Kenmore 11092581820 AUTOMATIC WASHER
Kenmore 11092582100 AUTOMATIC WASHER
Kenmore 11092582120 AUTOMATIC WASHER
Kenmore 11092582420 AUTOMATIC WASHER
Kenmore 11092582800 AUTOMATIC WASHER
Kenmore 11092582820 AUTOMATIC WASHER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11095 CEILING FAN
Kenmore 11096195120 ELECTRIC DRYER
Kenmore 11096195500 ELECTRIC DRYER
Kenmore 11096195510 DRYER FEATURE SHEET
Kenmore 11096195520 ELECTRIC DRYER
Kenmore 11096195800 ELECTRIC DRYER
Kenmore 11096195810 DRYER FEATURE SHEET
Kenmore 11096195820 ELECTRIC DRYER
Kenmore 11096210100 DRYER-FEATURE SHEET
Kenmore 11096220100 DRYER-FEATURE SHEET
Kenmore 11096250100 DRYER-FEATURE SHEET
Kenmore 11096260100 DRYER FEATURE SHEET
Kenmore 11096263100 DRYER-FEATURE SHEET
Kenmore 11096263800 DRYER-FEATURE SHEET
Kenmore 11096264100 DRYER FEATURE SHEET
Kenmore 11096264800 DRYER FEATURE SHEET
Kenmore 11096271100 DRYER FEATURE SHEET
Kenmore 11096271600 DRYER FEATURE SHEET
Kenmore 11096271800 DRYER FEATURE SHEET
Kenmore 11096272000 ELECTRIC DRYER
Kenmore 11096272100 DRYER FEATURE SHEET
Kenmore 11096272600 DRYER FEATURE SHEET
Kenmore 11097091100 GAS DRYER
Kenmore 11097091300 GAS DRYER
Kenmore 11097091700 GAS DRYER
Kenmore 11097091800 GAS DRYER
Kenmore 11097093100 GAS DRYER
Kenmore 11097093300 GAS DRYER
Kenmore 11097093500 GAS DRYER
Kenmore 11097093700 GAS DRYER
Kenmore 11097093800 GAS DRYER
Kenmore 11097094100 GAS DRYER
Kenmore 11097094300 GAS DRYER
Kenmore 11097094500 GAS DRYER
Kenmore 11097094700 GAS DRYER
Kenmore 11097094800 GAS DRYER
Kenmore 11097195100 GAS DRYER
Kenmore 11097195110 DRYER FEATURE SHEET
Kenmore 11097195120 GAS DRYER
Kenmore 11097195500 GAS DRYER
Kenmore 11097195510 DRYER FEATURE SHEET
Kenmore 11097195520 GAS DRYER
Kenmore 11097195800 GAS DRYER
Kenmore 11097195810 DRYER FEATURE SHEET
Kenmore 11097195820 GAS DRYER
Kenmore 11097210100 DRYER-FEATURE SHEET
Kenmore 11097220100 DRYER-FEATURE SHEET
Kenmore 11097250100 DRYER-FEATURE SHEET
Kenmore 11097260100 DRYER FEATURE SHEET
Kenmore 11097264100 DRYER FEATURE SHEET
Kenmore 11097264800 DRYER FEATURE SHEET
Kenmore 11097271100 DRYER FEATURE SHEET
Kenmore 11097271600 DRYER FEATURE SHEET
Kenmore 11097271800 DRYER FEATURE SHEET
Kenmore 11097272100 DRYER FEATURE SHEET
Kenmore 11097272600 DRYER FEATURE SHEET
Kenmore 11097272800 DRYER SPECIFICATIONS
Kenmore 11097273100 DRYER FEATURE SHEET
Kenmore 11097273600 DRYER FEATURE SHEET
Kenmore 11097273800 DRYER FEATURE SHEET
Kenmore 11097274100 DRYER FEATURE SHEET
Kenmore 11097274600 DRYER FEATURE SHEET
Kenmore 11097274800 DRYER FEATURE SHEET
Kenmore 11097278100 DRYER FEATURE SHEET
Kenmore 11097278800 DRYER FEATURE SHEET
Kenmore 11097280100 DRYER FEATURE SHEET
Kenmore 110985000 SEARS DIRECT DISCHARGE WALL FAN
Kenmore 110985100 VERTICAL DISCHARGE FAN
Kenmore 11098518200 ELECTRIC DRYER
  #2 (permalink)
Old 07-27-2007, 10:12 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
You may not be able to turn the bottom of the agitator by hand.
If the washer does not make a sound during pump out or spin then it's time to check the washer lid switch.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Relay switch wont engage automaticaly to turn ac on per thermostat lolo Heating, Ventilation, and Air Conditioning (HVAC) 3 01-16-2008 06:56 PM
My dryer blows hot air but doesn't turn. staceyo Dryer Repair 1 07-26-2007 08:45 PM
