Discuss
Help! My washer won't change cycles and keeps overflowing!
 in
Washer Repair
Please help! We got this washer off of Craigslist two years ago, so I'm not sure exactly how old it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help! My washer won't change cycles and keeps overflowing!
  #1 (permalink)
Old 03-20-2011, 11:26 PM
Junior Member
kaseysfan22 is on a distinguished road
Exclamation Help! My washer won't change cycles and keeps overflowing!
Model Number: 26912690   Brand: Kenmore   Age: 1 - 5 years
Please help! We got this washer off of Craigslist two years ago, so I'm not sure exactly how old it is. It has always worked great with no problems. But now it suddenly won't change cycles. We have to set a timer, and physically change it to the next cycle or it will overflow and flood the entire room. And tonight it started filling with water after the spin cycle was finished, which of corse flooded the room again. We are not sure what to do. I would rather not have to call somebody to repair it. Anybody have any ideas or suggestions? Thanks in advance.
Related Models
Maytag 2699A Refrigerator/Freezer
Maytag 2699W Refrigerator/Freezer
Jenn-Air 2700EEL WALLOVEN- STD ELE
Hoover 2720
Hoover 2726
Roper 2733*0A Ranges, Electric*
Roper 2733W0A Ranges, Electric*
Roper 2735*0A Ranges, Electric*
Jenn-Air 2750ELS WALLOVEN- STD ELE
Roper 2763*0A Ranges, Electric*
Roper 2763W0A Ranges, Electric*
Roper 2765*0A Ranges, Electric*
Roper 2765W0A Ranges, Electric*
Jenn-Air 2770ELD WALLOVEN- STD ELE
Jenn-Air 2775ELD WALLOVEN- STD ELE
Hoover 2800
Frigidaire 2803 GAS RANGE
Frigidaire 2803-80B GAS RANGE
Frigidaire 28044 FRIGIDAIRE GAS RANGE
Frigidaire 280440C GAS RANGE
Frigidaire 280447C GAS RANGE
Frigidaire 2809A GAS RANGE
Frigidaire 2811 GAS RANGE
Frigidaire 2812A GAS RANGE
Frigidaire 2813-80B GAS RANGE
Frigidaire 2813A GAS RANGE
Frigidaire 2819A GAS RANGE
Frigidaire 2820A GAS RANGE
Frigidaire 282240A GAS RANGE
Frigidaire 282240B GAS RANGE
Frigidaire 282240C GAS RANGE
Frigidaire 282247B GAS RANGE
Frigidaire 282247C GAS RANGE
Frigidaire 2822A GAS RANGE
Frigidaire 2823 GAS RANGE
Frigidaire 2823-80B GAS RANGE
Frigidaire 2828A GAS RANGE
Frigidaire 2829A GAS RANGE
Hoover 2830
Frigidaire 2833 GAS RANGE
Frigidaire 2833-80B GAS RANGE
Frigidaire 2834-80A GAS RANGE
Frigidaire 2834-80B FRIGIDAIRE GAS RANGE
Frigidaire 2834-87B FRIGIDAIRE GAS RANGE
Frigidaire 283440A GAS RANGE
Frigidaire 283440B GAS RANGE
Frigidaire 283440C FRIGIDAIRE GAS RANGE
Frigidaire 283440D GAS RANGE
Frigidaire 283447B GAS RANGE
Frigidaire 283447C FRIGIDAIRE GAS RANGE
Frigidaire 283447D GAS RANGE
Frigidaire 283460B GAS RANGE
Frigidaire 283460C GAS RANGE
Frigidaire 283467B GAS RANGE
Frigidaire 283467C GAS RANGE
Hoover 2836
Frigidaire 28364 GAS RANGE
Frigidaire 2841A GAS RANGE
Frigidaire 284260A GAS RANGE
Frigidaire 284267A GAS RANGE
Frigidaire 2843-80A GAS RANGE
Frigidaire 2843-80B GAS RANGE
Frigidaire 2843-80C GAS RANGE
Roper 2843W0A Ranges, Electric*
Frigidaire 284440A GAS RANGE
Frigidaire 284440B GAS RANGE
Frigidaire 284447A GAS RANGE
Frigidaire 284447B GAS RANGE
Frigidaire 2851A GAS RANGE
Frigidaire 2853 GAS RANGE
Frigidaire 28564 FRIGIDAIRE GAS RANGE
Frigidaire 285640A FRIGIDAIRE GAS RANGE
Frigidaire 285640B GAS RANGE
Frigidaire 285640D GAS RANGE
Frigidaire 285640E GAS RANGE
Frigidaire 285647A FRIGIDAIRE GAS RANGE
Frigidaire 285647B GAS RANGE
Frigidaire 285647D GAS RANGE
Frigidaire 285647E GAS RANGE
Frigidaire 285660A GAS RANGE
Frigidaire 285667A GAS RANGE
Frigidaire 28584 GAS RANGE
Frigidaire 285840A GAS RANGE
Frigidaire 285840B GAS RANGE
Frigidaire 285840C GAS RANGE
Frigidaire 285840D GAS RANGE
Frigidaire 285847A GAS RANGE
Frigidaire 285847B GAS RANGE
Frigidaire 285847C GAS RANGE
Frigidaire 285847D GAS RANGE
Frigidaire 28586 FRIGIDAIRE GAS RANGE
Frigidaire 285860A GAS RANGE
Frigidaire 285860B FRIGIDAIRE GAS RANGE
Frigidaire 285860C FRIGIDAIRE GAS RANGE
Frigidaire 285867A GAS RANGE
Frigidaire 28594 FRIGIDAIRE GAS RANGE
Frigidaire 285940A FRIGIDAIRE GAS RANGE
Frigidaire 285940B GAS RANGE
Frigidaire 285941A FRIGIDAIRE GAS RANGE
Frigidaire 285947A FRIGIDAIRE GAS RANGE
Frigidaire 285947B GAS RANGE
Frigidaire 2859A GAS RANGE
Frigidaire 2861A GAS RANGE
Frigidaire 2864 GAS RANGE
Frigidaire 2864-80B GAS RANGE
Frigidaire 2869A GAS RANGE
Frigidaire 2871A GAS RANGE
Roper 2872*0A Ranges, Electric*
Frigidaire 2872A GAS RANGE
Roper 2872W0A Ranges, Electric*
Frigidaire 2873 GAS RANGE
Frigidaire 2873B GAS RANGE
Frigidaire 2879A GAS RANGE
Frigidaire 2881 GAS RANGE
Frigidaire 2883 GAS RANGE
Roper 2883*10 Ranges, Electric*
Frigidaire 2883-80A GAS RANGE
Frigidaire 2883-81A GAS RANGE
Frigidaire 2883-81B GAS RANGE
Roper 2883W10 Ranges, Electric*
  #2 (permalink)
Old 03-22-2011, 05:54 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Do you feel lucky? If so, clean out the tube going from the water pressure switch to the tub, and see if that doesn't make things right.
Let us know
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Washer will not change cycles mestes Washer Repair 7 01-06-2011 12:11 PM
GE Washer is overflowing washerman Washer Repair 1 04-07-2010 05:02 PM
washer overflowing jlh Washer Repair 3 12-09-2008 06:57 AM
Washer will not change cycles rnti2qt Washer Repair 1 09-06-2008 03:48 PM
washer will not change cycles automatically bad bart Washer Repair 0 10-16-2007 12:23 PM
