We purchased a replacement user interface assembly from your store for our Kenmore Oasis washing machine. We have opened the console and removed the screws, but can't determine how to lift the locking tabs to replace the assembly. We don't want to force the tabs for fear of damaging the cover. Is there a trick to lifting the tabs to remove the cover?
The user interface assembly is held to the console insert panel by three screws and two locking tabs. After the screws are removed, lift each of the locking tabs to remove the back cover of the user interface assembly.
Remove the wash cycle selector switch from the user interface assembly opening by lifting the locking tab on the wash cycle selector switch and turning the selector switch in a counterclockwise direction.
Three locking tabs located at the bottom of the console insert panel secure the user interface assembly to the console insert panel. Using a flat-blade screwdriver, gently apply pressure to the locking tabs to release the user interface assembly.
