Discuss
kitchen aide
 in
Washer Repair
washer stops at rinse cycle. I was able to remove the clothing and turn the knob to reset and it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kitchen aide
  #1 (permalink)
Old 03-19-2011, 05:28 PM
Junior Member
tdma is on a distinguished road
Default kitchen aide
Model Number: kaws 850LQ   Brand: Kitchen Aid   Age: 5 - 10 years
washer stops at rinse cycle. I was able to remove the clothing and turn the knob to reset and it spun and drained the washer. I thought it was just a overload issue.
The next load. very light, did the same thing, I turned the load size knob
from large to medium and then turned to reset again and it finished the load again.
Why does it keep stopping at the rinse cycle with the washer full of water?
Thanks,
Gerry
Related Models
Whirlpool KAWS577EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS577EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS677EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS677EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS700EQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool KAWS700EZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool KAWS700GQ0 AUTOMATIC WASHER
Whirlpool KAWS700GT0 AUTOMATIC WASHER
Whirlpool KAWS700GZ0 AUTOMATIC WASHER
Whirlpool KAWS700JQ0 RESIDENTIAL WASHER
Whirlpool KAWS700JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ3 RESIDENTIAL WASHER
Whirlpool KAWS700JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS700JT0 RESIDENTIAL WASHER
Whirlpool KAWS700JT1 RESIDENTIAL WASHERS
Whirlpool KAWS700JT2 RESIDENTIAL WASHERS
Whirlpool KAWS700JT3 RESIDENTIAL WASHER
Whirlpool KAWS700JT4 RESIDENTIAL WASHERS
Whirlpool KAWS700LQ0 RESIDENTIAL WASHERS
Whirlpool KAWS700LT0 RESIDENTIAL WASHERS
Whirlpool KAWS750GQ0 AUTOMATIC WASHER
Whirlpool KAWS750GQ1 AUTOMATIC WASHER
Whirlpool KAWS750GT1 AUTOMATIC WASHER
Whirlpool KAWS750GZ0 AUTOMATIC WASHER
Whirlpool KAWS750GZ1 AUTOMATIC WASHER
Whirlpool KAWS750JQ0 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ3 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS750JT0 RESIDENTIAL WASHERS
Whirlpool KAWS750JT1 RESIDENTIAL WASHERS
Whirlpool KAWS750JT2 RESIDENTIAL WASHERS
Whirlpool KAWS750JT3 RESIDENTIAL WASHERS
Whirlpool KAWS750JT4 RESIDENTIAL WASHERS
Whirlpool KAWS750LQ0 AUTOMATIC WASHER
Whirlpool KAWS750LQ1 AUTOMATIC WASHER
Whirlpool KAWS750LQ2 AUTOMATIC WASHER
Whirlpool KAWS750LQ3 AUTOMATIC WASHER
Whirlpool KAWS750LQ4 AUTOMATIC WASHER
Whirlpool KAWS750LT0 AUTOMATIC WASHER
Whirlpool KAWS750LT1 AUTOMATIC WASHER
Whirlpool KAWS750LT2 AUTOMATIC WASHER
Whirlpool KAWS750LT3 AUTOMATIC WASHER
Whirlpool KAWS750LT4 AUTOMATIC WASHER
Whirlpool KAWS777EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS777EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS800GQ0 AUTOMATIC WASHER
Whirlpool KAWS800GQ1 AUTOMATIC WASHER
Whirlpool KAWS800GZ0 AUTOMATIC WASHER
Whirlpool KAWS800GZ1 AUTOMATIC WASHER
Whirlpool KAWS850GQ0 AUTOMATIC WASHER
Whirlpool KAWS850GQ1 AUTOMATIC WASHER
Whirlpool KAWS850GT0 AUTOMATIC WASHER
Whirlpool KAWS850GT1 AUTOMATIC WASHER
Whirlpool KAWS850GZ0 AUTOMATIC WASHER
Whirlpool KAWS850GZ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ0 AUTOMATIC WASHER
Whirlpool KAWS850JQ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ2 AUTOMATIC WASHER
Whirlpool KAWS850JQ3 AUTOMATIC WASHER
Whirlpool KAWS850JQ4 AUTOMATIC WASHER
Whirlpool KAWS850JT0 AUTOMATIC WASHER
Whirlpool KAWS850JT1 AUTOMATIC WASHER
Whirlpool KAWS850JT2 AUTOMATIC WASHER
Whirlpool KAWS850JT3 AUTOMATIC WASHER
Whirlpool KAWS850JT4 AUTOMATIC WASHER
Whirlpool KAWS850LE0 AUTOMATIC WASHER
Whirlpool KAWS850LE1 AUTOMATIC WASHER
Whirlpool KAWS850LE2 AUTOMATIC WASHER
Whirlpool KAWS850LQ0 AUTOMATIC WASHER
Whirlpool KAWS850LQ1 AUTOMATIC WASHER
Whirlpool KAWS850LQ2 AUTOMATIC WASHER
Whirlpool KAWS850LT0 AUTOMATIC WASHER
Whirlpool KAWS850LT1 AUTOMATIC WASHER
Whirlpool KAWS850LT2 AUTOMATIC WASHER
Whirlpool KAWS855JE0 WASHER
Whirlpool KAWS855JE1 WASHER
Whirlpool KAWS855JE2 WASHER
Whirlpool KAWS855JE3 WASHER
Whirlpool KAWS855JE4 WASHER
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 QT. STAND MIXER
Whirlpool KB26G1XAC3 6 QT. STAND MIXER
Whirlpool KB26G1XAC5 6 QT. STAND MIXER
Whirlpool KB26G1XBU3 6 QT. STAND MIXER
Whirlpool KB26G1XBU5 6 QT. STAND MIXER
Whirlpool KB26G1XER3 6 QT. STAND MIXER
Whirlpool KB26G1XER5 6 QT. STAND MIXER
Whirlpool KB26G1XGN3 6 QT. STAND MIXER
Whirlpool KB26G1XGR3 6 QT. STAND MIXER
Whirlpool KB26G1XGR5 6 QT. STAND MIXER
Whirlpool KB26G1XMC3 6 QT. STAND MIXER
Whirlpool KB26G1XMC5 6 QT. STAND MIXER
Whirlpool KB26G1XMY3 6 QT. STAND MIXER
Whirlpool KB26G1XMY5 6 QT. STAND MIXER
Whirlpool KB26G1XOB3 6 QT. STAND MIXER
Whirlpool KB26G1XOB5 6 QT. STAND MIXER
Whirlpool KB26G1XPT3 6 QT. STAND MIXER
  #2 (permalink)
Old 03-19-2011, 06:57 PM
Junior Member
Default
I may have the answer to my own question.
After reading the manual it says the machine must be level. It appears to be tilted a bit with the front down. I wonder if this is causing it to shut down when heavily loaded?
In the morning I will get out a level and some wrenches.
Do any of you pro's have any input on this?
Gerry
  #3 (permalink)
Old 03-20-2011, 08:30 AM
Junior Member
Default
I balanced the washer and am running a light load as we speak.
Wife seems to think the whole process is taking to long for a load.
Can anyone point me to info on how long each cycle should run?
I am not in the mood to changed a 133dollar timer for no reason.
  #4 (permalink)
Old 03-20-2011, 09:03 AM
Junior Member
Default
balancing the machine did not fix the problem.
load seems to stop mid cycle. the timer does advance but seems to be very slow. I had to manualy advance the timer to get the load finished, then they where not clean, I believe i advanced it past the wash cycle just to get the machine to empty.
When i manually advanced it to spin it seemed to operate normally.
Is my timer shot?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchen aide dryer not turning on dakota70 Dryer Repair 1 07-13-2010 05:18 PM
Kitchen Aide Self-Cleaning Problem pallasc Oven Repair (including Ranges and Cooktops) 0 03-15-2010 09:09 AM
kitchen aide washer waki175 Washer Repair 1 12-08-2009 05:45 PM
Kitchen Aide Burner Valve herrz311 Oven Repair (including Ranges and Cooktops) 0 04-08-2009 01:55 PM
kitchen aide k45 hubie General Talk 0 02-19-2009 05:15 PM
