Discuss
Wet Spin
 in
Washer Repair
My washer goes completely through the cycles.However the spin cycles are slugish and the clothes are not dry enough
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Wet Spin
  #1 (permalink)
Old 10-23-2007, 10:28 PM
Mack Norton Mack Norton is offline
Junior Member
Mack Norton is on a distinguished road
Angry Wet Spin
Model Number: KAWS677EQO   Brand: Kitchen Aid   Age: 5 - 10 years
My washer goes completely through the cycles.However the spin cycles are slugish and the clothes are not dry enough to put into the dryer. What is the trouble with my washer.MN:confused
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 04:54 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull away front panel and remove water pump and motor. Turn tranny coupler clockwise till tub starts turning.If it's very hard to turn with two fingers, you have dragging brake shoes or something stuck in the tub.
Shine a bright lite in the spin basket and look for something. If nothing, you probably have dragging brake shoes.
Remove agitator and loosen drive block nut on top of the spin basket, pound on the nut and pull up on the spin basket,basket should break loose.
Remove tranny and pry down brake shoes and spin tube. Remove spring and C clips and brake shoes and order new ones.
If not available, you can fix your brake shoes by grinding down the pads 1/4 inch or more and re-install.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
