Discuss
Maytag Washer Inlet valve - water level switch
 in
Washer Repair
I have an older Maytag Washer - it has been perfect. Started a slow leak just under the tub in the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer Inlet valve - water level switch
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-23-2007, 08:36 PM
reisman reisman is offline
Junior Member
reisman is on a distinguished road
Default Maytag Washer Inlet valve - water level switch
Model Number: LAT8405AAM   Brand: Maytag   Age: More than 10 years
I have an older Maytag Washer - it has been perfect. Started a slow leak just under the tub in the central seal / bearing, which was successfully replaced. At the same time, any scale and scum inside the unit was completely cleaned away. Overall a very clean unit anyway - no oil leaks or anything serious, and all belts were replaced. After this we noticed the water level is up above the top level of tiny holes / ports inside the drum, on Extra Large Load Settings - I understand this is about 3/4" too high, as when the spin cycle first begins, and the drum begins to turn, it sloshes about 1-2 quarts of water out over the top of the drum. I have cleaned the hose going to the water level switch perfectly, and I can blow through it easily now - it was not that easy at first. There is a screw on the diaphragm for the water level pressure switch, and you can turn it in (clockwise) or out (counter-clockwise). I want to know what to do to lower the water level about 3/4" on Extra Large Load fills, please. PLEASE HELP ME OUT.
THANK YOU KINDLY IN ADVANCE.
Mike Reisman
reism@cox.net
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New Water Inlet valve has different fittings cubbedges Refrigerator & Freezer Repair 2 10-27-2007 08:38 AM
Kenmore dishwasher not spraying water at the third level ilikebikes Dishwasher Repair 1 10-17-2007 03:34 PM
Water inlet valve m/c Refrigerator & Freezer Repair 2 07-31-2007 10:34 PM
Ge inlet valve Mark Dishwasher Repair 1 07-20-2007 06:22 PM
Water inlet valve gentleben Refrigerator & Freezer Repair 1 07-19-2007 11:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
