If this is posted twice sory I did not see it in washer repair forum after I posted.
I can not get my washer to rinse. I put a new timer on it and it still does not work. It does wash but when it comes to the rinse cycle it just sit there (the timer) and does not move. The washer needs to fill in order to move on threw the cycle. I took off the fill pressure hose/tube (not the water hose) to the fill pressure switch and blew into it to trick the washer it to thinking it was full of water and it agitates (works). I do not know why it will not fill for rinse. Hope for the help. Thanks
