stumpt
#1 Posted : Friday, March 18, 2011 4:24:10 PM(UTC)
stumpt
I can not get my washer to rinse. I put a new timer on it and it still does not work.
It does wash but when it comes to the rinse cycle it just sit there (the timer) and does not move. The washer needs to fill in order to move on threw the cycle.
I took off the fill pressure hose/tube (not the water hose) to the fill pressure switch and blew into it to trick the washer it to thinking it was full of water and it agitates (works).
I do not know why it will not fill for rinse. Hope for the help. Thanks
sidfink43
#2 Posted : Sunday, March 20, 2011 6:06:09 AM(UTC)
sidfink43
Try checking the lid switch. You can temporarily by-pass it with a jumper wire. If that fixes things, replace the switch.
Good Luck!
stumpt
#3 Posted : Sunday, March 20, 2011 1:24:34 PM(UTC)
stumpt
Thanks. I will look at the switch but I do not think it is the problem because it fills for wash and not for rinse.
The lid just stops it from agitating not filling with water. If you open the lid while it is filling for wash it will fill to the level that you selected and then stop till you shut the lide.
It is when you open the lid after it fills that it will not agitate.
It will continue to fill for wash when you open lide.
Washer will not rinse or spin (Washer Repair)
by Ktaka23 4/9/2014 9:11:11 AM(UTC)
washer will not rinse right cloth still wet (Washer Repair)
by bob n jack 5/3/2012 3:23:15 PM(UTC)
Washer will not Rinse (Washer Repair)
by dvidler1 8/7/2011 5:26:37 AM(UTC)
Front load washer will not rinse/drain or spin out (Washer Repair)
by haroldlm 12/9/2009 9:15:50 AM(UTC)
washer will not rinse/ new timer replaced (Washer Repair)
by bak 10/22/2009 3:59:59 PM(UTC)
ge washer will not rinse or spin (Washer Repair)
by tmm313psu 10/2/2009 3:48:31 PM(UTC)
by jimbo0555 6/26/2009 5:20:11 PM(UTC)
Washer will not rinse (Washer Repair)
by tempo1001 3/24/2008 1:54:13 PM(UTC)
