Discuss
Whirlpool Won't Agitate, Pump, or Spin...Sometimes
 in
Washer Repair
Hello: Our Whirlpool direct drive unit works sometimes, but when it doesn't, nothing works. It won't agitate, pump, or spin.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Won't Agitate, Pump, or Spin...Sometimes
  #1 (permalink)
Old 03-18-2011, 04:16 PM
Junior Member
johntlewis is on a distinguished road
Default Whirlpool Won't Agitate, Pump, or Spin...Sometimes
Model Number: Super Capacity Plus   Brand: Whirlpool   Age: 5 - 10 years
Hello:
Our Whirlpool direct drive unit works sometimes, but when it doesn't, nothing works. It won't agitate, pump, or spin. The motor does make a sound as if it is trying to turn. It will sometimes run normal and then all of a sudden lock up. If we let the motor run long when it's locked up, we can detect a slight burning smell.
We replaced the switch first and then we replaced the coupler. The old coupler looked good, but nothing changed with the new. Now I opened it back up and hand turned the pump and it turned okay. I also turned on the part between the transmission and the bottom of the tub and it seemed to turn okay.
What do you think the problem might be?
Ads By Google
Related Models
Jenn-Air SVD48600B RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600BC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600P RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PT RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600W RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600WC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVE47100B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
  #2 (permalink)
Old 03-19-2011, 05:18 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I think your motor is in the process of failing. See if there is a tech sheet inside the console that will give you the readings on the windings.
Also check to make sure that the new coupling is not binding and something is not jamming the pump.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag will agitate,spin, won't pump out water DealerMan Washer Repair 1 10-18-2009 07:51 AM
Washer will not agitate but will pump and spin wor96 Washer Repair 6 08-02-2009 01:30 PM
Replaced pump. Spin yes, agitate no. bakjar Washer Repair 2 03-09-2009 05:06 PM
GE topload will not agitate/spin will pump Alizabeth Washer Repair 1 02-23-2009 06:09 PM
maytag will not spin agitate or pump drembo Washer Repair 7 12-25-2007 02:37 AM
