Discuss
spin dry only on light loads
 in
Washer Repair
on heavier loads water is pumped out but load not spun dry.remove some load and use drain /spin option
Appliance Repair Forum > Appliance Repair Help > Washer Repair » spin dry only on light loads
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-27-2007, 11:05 AM
gwc36@verizon.net gwc36@verizon.net is offline
Junior Member
gwc36@verizon.net is on a distinguished road
Default spin dry only on light loads
Model Number: 110.22052100   Brand: Kenmore   Age: 1 - 5 years
on heavier loads water is pumped out but load not spun dry.remove some load and use drain /spin option and load spins dry but seems nosier in doing so. with load not sufficiently lightned , sounds as though it is trying to spin but no spin .the loads that do not spin dry are of a size routinely handled by this machine in the past.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-27-2007, 04:36 PM
Adam / APP Team Adam / APP Team is offline
Service Pro
APP Team
Adam / APP Team is on a distinguished road
Default
Its possible there is something caught between the tub or the clutch is worn.
I
f you remove the cabinet you can carefully run it. Check the clutch drum is to see if its after you have run it in spin. You may also notice the noise coming from it.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
