I'm not sure of machine's age but here goes - This washer when I first approached it was giving an F-24 code so I changed the temperature sensor as instructed but after doing so the washer would give an F-30 code which was a dispenser motor code...another tech came and suggested that the CCU and door interlock be changed so I did that as well. NOW the washer is giving us a 1E code...HELP PLEASE?! :confused: And no, I have not changed the dispenser motor and during this whole experience I've yet to have water enter the washer. We jumped the pump so it is functional, it's like the neutral is gone after testing for voltage.
Forgot to say, the door lock is working, and the machine will/would go through its diagnostic check then now anyway ends by giving me the 1E code.
