Discuss
water pump going bad
 in
Washer Repair
Hello, Our water pump on our washing machine is making a loud grinding, humming noise when pumping water out,louder
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water pump going bad
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-23-2007, 04:10 PM
CAT88 CAT88 is offline
Junior Member
CAT88 is on a distinguished road
Default water pump going bad
Model Number: 110.45981400   Brand: Kenmore   Age: 1 - 5 years
Hello, Our water pump on our washing machine is making a loud grinding, humming noise when pumping water out,louder as it empties, I've taken the pump out and clean it, there was no signs of any blockage anywhere inside. just wanted to make sure it couldn't be something else electrical that could cause this .The washer is only 2.5 years old. We have had alot of problems with this he4t washer by kenmore.Thanks for any help on this. Sincerely Craig
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-23-2007, 04:42 PM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Default
If it is grinding and making noise sounds like it may damaged, I would replace it and check your prockets closer in the future before stuff is put into the washer, items getting into the pump is what damages them..
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG pump may be bad or have something stuck Jamiepe Washer Repair 2 10-24-2007 10:16 AM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 07:41 PM
Drain Pump loadster Dishwasher Repair 1 08-07-2007 06:35 PM
Replacing Pump pdiddy Washer Repair 0 07-23-2007 12:43 AM
Changing Pump pdiddy Washer Repair 1 07-20-2007 06:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
