| » water pump going bad |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 110.45981400 Brand: Kenmore Age: 1 - 5 years
Hello, Our water pump on our washing machine is making a loud grinding, humming
noise when pumping water out,louder as it empties, I've taken the pump out and clean it, there was no signs of any blockage anywhere inside. just wanted to make sure it couldn't be something else electrical that could cause this .The washer is only 2.5 years old. We have had alot of problems with this he4t washer by kenmore.Thanks for any help on this. Sincerely Craig |
If it is grinding and making noise sounds like it may damaged, I would replace it and check your prockets closer in the future before stuff is put into the washer, items getting into the pump is what damages them..
__________________
-Serving North Central Texas and Southern Oklahoma since 1978. www.samsservicesenter.com |
| Display Modes | |
| LG pump may be bad or have something stuck | Jamiepe | Washer Repair | 2 | 10-24-2007 10:16 AM |
| Washer won't drain during spin cycle. Water Pump Belt discovered on floor | sandydjdm | Washer Repair | 1 | 08-14-2007 07:41 PM |
| Drain Pump | loadster | Dishwasher Repair | 1 | 08-07-2007 06:35 PM |
| Replacing Pump | pdiddy | Washer Repair | 0 | 07-23-2007 12:43 AM |
| Changing Pump | pdiddy | Washer Repair | 1 | 07-20-2007 06:05 PM |
