Maytag washer fills cold water continually
My Maytag washer fills continuously from cold water hose when machine is turned off and power is disconnected. It then seeps out the fontloading door and has caused 3 floods in the past week. Have to turn off water and disconnect hose from cold water at wall 2 minutes before spin cycle ends. Otherwise it functions on any wash cycle. Please help !!
Replacement parts for MAH2400A models | AppliancePartsPros.com Sounds like your cold valve (Item 7 in Section 1) needs replacing. |
| All times are GMT -7. The time now is 02:47 PM. |
