the washer doent seem to drain properly, i clean out the pump.It seem to work for awhile, but now it seems to just drain once in a while. the code f1 and 5d comes up, and the pump seem to be hot.but stops spinning and draining...thanks any advise would be of great help.
thank you Hete beste Chris
You should have found a tech sheet inside the lower service panel which explains the error codes to you and explains how to put the machine into a diagnostic mode.
Concentrate on the water pressure switch and the main control unit.
