Discuss
LG Washer Pump Replacement Procedure
 in
Washer Repair
Model: LG Tromm WH2477HW Age of Machine: approx. 4 years Symptoms: Water remains in the drum after a wash cycle.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG Washer Pump Replacement Procedure
  #1 (permalink)
Old 03-15-2011, 04:33 PM
Junior Member
dz63 is on a distinguished road
Default LG Washer Pump Replacement Procedure
Model Number: WH2477HW   Brand: -other-   Age: 1 - 5 years
Problem: The drain pump was sluggish due to sediment build up inside the pump.
Drain Motor: Part number: 4681EA2001D
Let's Get Started!
1. Unplug the washer and shut off the water supply lines. Remove the drain access cover, pull the drain hose out, pull the plug out of the end of the hose and drain the tub. In my case, the hose was plugged with debris, so I had to partially screw open the strainer to drain the water out one tray at a time.
2. Remove the strainer and clean out all debris. Remove the Philips screws circled in red. Keep track of which screws go where. The screws on this machine are all different lengths. Pull the drain cover away from the machine.
3. Remove the two Philips screws circled in red. Keep track of which screws go where. The screws on this machine are all different lengths.
4. Slide the top cover toward the back of the machine. I found it necessary to hit the cover with the palm of my hand to get it to move back. Remove the top cover and set aside.
5. Remove the detergent drawer by pressing down on the light blue latch (red arrow) and pulling the drawer from the machine.
6. Disconnect the three wiring harness connectors at the front of the machine by pushing down on the latch and pulling apart.
7. Remove two Philips screws circles in red. These screws are stainless steel. Don’t mix them up with the other ones.
8. Remove the Philips screw circles in red.
9.Lift the front plastic cover up at the two places (where the red arrows are shown) and remove the front control panel. Set the control panel aside.
10. Open the front door and remove gasket retaining spring. In order to do this you will need to stretch the spring with a large pair of snap ring pliers or in my case, I modified a cheap pair of $7 brake spring pliers that I picked up a Princess Auto.
11. Pull the rubber door gasket away from the front sheet metal opening.
12. Remove 4 Philips screws (circled in red). Tilt the front cover forward to access the door switch.
13. Disconnect the wiring harness connector at the door switch.
14. Remove the front cover with door and set aside.
15. Pinch the hose clamps and remove them. Pull the two hoses off of the pump casing. Remove the two Philips screws circled in red.
16. Push down on the plastic tab to release the latch that holds the pump to the base (you can’t actually see this tab, you just have to “feel” for it), then slide the pump back into the machine to remove it. Disconnect the electrical wires. Brown = LINE. Black = NEUTRAL.
17. Remove the three Philips screws (circled in red) and separate the pump motor from the pump casing. There are more than 3 holes on the pump casing. Make a mental note which holes the screws came from.
18. Clean the casing out with hot water and an old toothbrush. Using an ohmmeter, check that the resistance across the motor terminals measures between 10-20 ohms. If the resistance is outside this range, replace the motor. Mine measured 13 ohms. Bench test the motor with 110VAC to ensure that the motor runs. Mine worked OK.
19.Using compressed air, I blew out the obstruction in the small rubber drain hose. There was an accumulation of grit and sediment in my hose.
20. Next, I connected compressed air to the green rubber boot that was formerly connect, d to the drain pump and blew air through it to ensure that the hose was not blocked. Mine was not blocked.
21.Next, I temporarily connected the front control panel, the door switch and the reassembled drain pump back up to the washing machine and temporarily ran the machine though a QC test mode by following the instructions found on page 16 of the service manual found at this link.
https://docs.google.com/fileview?id=0B5If-wTgYWH5MzYzYzAzNGQtMmNiNy00ZmFiLWI5NGQtODg0YTgzYTU 5MzJk&hl=en
At steps 1,2,3, and 11, the drain pump ran and I measured 110VAC across the motor terminals. This gave me the confidence to know that the problem was solved.
22. Reassemble the machine in the reverse order and test by running the washer through one complete cycle.
Ads By Google
Related Models
General Electric WHDRE526E1WW Washer
General Electric WHDRE526E6WW Washer
General Electric WHDRR418E1WW Washer
General Electric WHDRR418E3WW Washer
General Electric WHDRR418E4WW Washer
General Electric WHDRR418E5WW Washer
General Electric WHDRR418E6WW Washer
General Electric WHDRR418G0WW Washer
General Electric WHDSE820C0WW Washer
General Electric WHDSE820C1WW Washer
General Electric WHDSE820C9WW Washer
General Electric WHDSR209D0WW Washer
General Electric WHDSR209D1WW Washer
General Electric WHDSR209D3WW Washer
General Electric WHDSR209D4WW Washer
General Electric WHDSR209D5WW Washer
General Electric WHDSR209D6WW Washer
General Electric WHDSR209D7WW Washer
General Electric WHDSR209DAWW Washer
General Electric WHDSR209DBWW Washer
General Electric WHDSR209DCWW Washer
General Electric WHDSR209DDWW Washer
General Electric WHDSR209G0WW Washer
General Electric WHDSR209G2WW Washer
General Electric WHDSR315D0WW Washer
General Electric WHDSR315D5WW Washer
General Electric WHDSR315DAWW Washer
General Electric WHDSR315DBWW Washer
General Electric WHDSR315DCWW Washer
General Electric WHDSR316G0WW Washer
General Electric WHDSR417D0WW Washer
General Electric WHDSR417D5WW Washer
General Electric WHDVH626F0GG Washer
General Electric WHDVH626F0WW Washer
General Electric WHDVH660H0BB Washer
General Electric WHDVH660H0GG Washer
General Electric WHDVH660H0WW Washer
Whirlpool WHE33311 30" Electric Range
Whirlpool WHP1000SB1 Pedestal
Whirlpool WHP1000SK0 Pedestal
Whirlpool WHP1000SK1 Pedestal
Whirlpool WHP1000SL0 Pedestal
Whirlpool WHP1000SL1 Pedestal
Whirlpool WHP1000SQ0 Pedestal
Whirlpool WHP1000SQ1 Pedestal
Whirlpool WHP1000ST0 Pedestal
Whirlpool WHP1000ST1 Pedestal
Whirlpool WHP1000SU1 Pedestal
Whirlpool WHP1500SA0 Pedestal
Whirlpool WHP1500SA1 Pedestal
Maytag WHP1500SA1 Pedestal
Whirlpool WHP1500SB0 Pedestal
Whirlpool WHP1500SB1 Pedestal
Maytag WHP1500SB1 Pedestal
Whirlpool WHP1500SC0 Pedestal
Whirlpool WHP1500SC1 Pedestal
Maytag WHP1500SC1 Pedestal
Whirlpool WHP1500SL0 Pedestal
Whirlpool WHP1500SL1 Pedestal
Maytag WHP1500SL1 Pedestal
Whirlpool WHP1500SQ0 Pedestal
Whirlpool WHP1500SQ1 Pedestal
Maytag WHP1500SQ1 Pedestal
Whirlpool WHP1500ST0 Pedestal
Whirlpool WHP1500ST1 Pedestal
Maytag WHP1500ST1 Pedestal
Whirlpool WHP1500SU0 Pedestal
Whirlpool WHP1500SU1 Pedestal
Maytag WHP1500SU1 Pedestal
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" Electric Range Ceran Cooktop Self Clean
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
  #2 (permalink)
Old 04-23-2011, 12:54 PM
Junior Member
TrollSaw is on a distinguished road
Thumbs up Nice Job!!
Nice job on your post.
  #3 (permalink)
Old 08-13-2011, 10:06 AM
Junior Member
ctbasscatcher is on a distinguished road
Default Thank you
This could not have been any more helpful!! Awesome pics and tutorial!
Thank you!
  #4 (permalink)
Old 09-13-2011, 05:07 PM
Junior Member
caffeineme is on a distinguished road
Default Perfect Instructions!
This guide probably saved me 2 weeks of downtime, and almost certainly $200+. Instead, one $45 pump motor and overnight shipping and my family is back in business!
THANK YOU for taking the time to put this together. WOW! Thank you so much!!!
  #5 (permalink)
Old 11-14-2011, 05:28 PM
Junior Member
koko2yumyum is on a distinguished road
Default Thanks, what awesome instructions
Just finished replacing both the water pump and door seal with your instructions. They were incredibly easy to follow and saved me a bunch of money. We greatly appreciate your expertise and step-by-step procedure. You made a novice into a simi-pro.
  #6 (permalink)
Old 01-05-2012, 05:08 PM
Junior Member
Default
Thanks for the feedback. I am glad to hear that the procedure saved you time and money. It makes the time I spent taking the pictures and documenting the procedure all worthwhile!
Don
  #7 (permalink)
Old 01-05-2012, 05:10 PM
Junior Member
Default
Quote:
Thanks for the kind words and positive feedback. Glad that you found the procedure helpful.
  #8 (permalink)
Old 04-24-2012, 10:26 AM
Junior Member
jhhender is on a distinguished road
Default Thanks, and a question about the brake spring pliers
Thanks, really helpful tutorial!
I'm taking off the boot gasket for another reason, but I'd like to try the brake spring plier instead of the expensive dedicated tool. Could you give a quick explanation of how you made the necessary modifications to your pliers? Looks like you added a bit of a hook to each side--how'd you do it?
Thanks!
  #9 (permalink)
Old 04-24-2012, 03:59 PM
Junior Member
Default
Thanks!
I bought one of these for $7 at the local auto supply store....
http://www.amazon.com/Performance-To...307603&sr=8-23
...then bent the tips and ground them to a point like this....
It is a bit awkward to use - you have to pull the handles apart rather than squeeze them together to spread the spring, but it did the trick for me. Good Luck!
  #10 (permalink)
Old 04-25-2012, 11:28 AM
Junior Member
Red Ducati is on a distinguished road
Default Thank You So Much
You saved me big money. I called for service but they could not come until tomorrow. With time to kill I got on the internet and found your information. The pictures, advice on spring tool and instructions made the job go smooth.
Thanks Again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Dryer Motor Replacement Procedure dz63 Dryer Repair 15 03-06-2013 11:27 PM
Baffle Kit Replacement Procedure? (WP Duet) skysentinel Washer Repair 19 09-25-2012 11:02 AM
idler pulley replacement procedure rzastrow Dryer Repair 0 02-26-2011 03:49 PM
Fountain lever replacement procedure drburdi Refrigerator & Freezer Repair 0 07-18-2010 07:21 AM
motor/pump removal procedure Tom Bravenec Dishwasher Repair 0 01-13-2008 09:52 AM
