Help with the thrust bearing kit. Not sure about how the cam should be install,, do I just put the cam on or does it go a certain way for the brake to work - it seems the brake get stuck during the spin cycle it gets stuck and want move.. To loosen I have to move the pulley underneath.. then it goes again until I release the pulley then get stuck again.
