Discuss
washer will not spin or drain
 in
Washer Repair
The washer will was but will not go into the rinse or spin cycle. You can hear a small humming
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer will not spin or drain
  #1 (permalink)
Old 10-23-2007, 10:00 AM
Martha Shelby Martha Shelby is offline
Junior Member
Martha Shelby is on a distinguished road
Default washer will not spin or drain
Model Number: LXR7244JQ1   Brand: Whirlpool   Age: 5 - 10 years
The washer will was but will not go into the rinse or spin cycle. You can hear a small humming noise....any suggestions of what might be wrong?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 10:02 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
pull the pump off the front of the motor and jump the lid switch with a wire between the two wires (not the green one)start it in spin. If it goes replace pump if not pull motor off maybe broken motor coupler if not it is the clutch assy
  #3 (permalink)
Old 10-25-2007, 03:43 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the washer agitates ok, but no spin, it's probably a bad timer.If no agitate, probably a bad coupler.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer wont spin/drain AndreaB Washer Repair 0 10-12-2007 05:27 PM
washer won't drain and move to the spin cycle dwillia1 Washer Repair 0 09-14-2007 09:10 AM
Washer barely agitates, won't drain or spin jsc2010 Washer Repair 4 09-12-2007 03:55 AM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 07:37 AM
Washer will spin slowly but not drain Mikie Martin Washer Repair 0 07-31-2007 08:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
