The washer has been spilling water from the lower right corner. It looks like it is coming from the little chlorine tray, but I can't tell for certain if it's the tray or the hose or the connection. Any suggestions on how to test and where to find parts?
The way we find leaks is to take off the cabinet, by-pass the lid switch and see where it is leaking. If you are sure it is from the clorine dispenser then you can replace it, here is the part. Part number: AP3120227
I have removed the cabinet and determined the leak is coming from the tray, but can't determine if it's the tray or the connection with the hose. Guess I'll try reconnecting the hose with a new clamp and see if that does the trick. If not then I guess it's the tray. Thanks for your help.
MW
Great, sounds like you are on top of it.
