I have a maytag washer that continually drain besides the cure of bringing the hose up higher is there a part that needs to be replaced:cool: thanks for imput
Originally Posted by: sksmith2006 I have a maytag washer that continually drain besides the cure of bringing the hose up higher is there a part that needs to be replaced:cool: thanks for imput SK, Sounds like you have a syphonning problem, top of drain pipe is too low. The heigth of your drain line needs to be 36 inches high from floor level to the top of the drain pipe, for proper fill levels and operation. Lower than that, and most of your fill settings will syphon through the washer and it will not fill. That's where you want to start. :) :) :)
