Discuss
Can higher water pressure cause leaking?
 in
Washer Repair
We have a GE washer that had a new fill valve/solenoid installed a little over two years ago. Performed fine
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Can higher water pressure cause leaking?
  #1 (permalink)
Old 03-13-2011, 05:04 PM
Junior Member
tealbingy is on a distinguished road
Default Can higher water pressure cause leaking?
Model Number: WWA8310GALAD   Brand: GE   Age: More than 10 years
We have a GE washer that had a new fill valve/solenoid installed a little over two years ago. Performed fine until we took it to a rental property. Now it appears to leak at the valve, but we're not sure; we switched the machine out and brought it home to investigate - and it won't leak when hooked up to our water.
Water pressure here, about 34 lbs. We don't know the number for the rental, but the pressure is definitely higher. Can water pressure that is too high cause a fill valve (or any washer part) to leak?
Ads By Google
Related Models
General Electric WWA8310GBL Washer
General Electric WWA8314PML Washer
General Electric WWA8314VKL Washer
General Electric WWA8314VLL Washer
General Electric WWA8318LAL Washer
General Electric WWA8318LBL Washer
General Electric WWA8319VCL Washer
General Electric WWA8320BAL Washer
General Electric WWA8320GAL Washer
General Electric WWA8320GBL Washer
General Electric WWA8320VCL Washer
General Electric WWA8324BAL Washer
General Electric WWA8324GAL Washer
General Electric WWA8324GBL Washer
General Electric WWA8326LAL Washer
General Electric WWA8326LBL Washer
General Electric WWA8330BAL Washer
General Electric WWA8330GAL Washer
General Electric WWA8330GBL Washer
General Electric WWA8340BAL Washer
General Electric WWA8340GAL Washer
General Electric WWA8340GBL Washer
General Electric WWA8340VCL Washer
General Electric WWA8344BAL Washer
General Electric WWA8344VCL Washer
General Electric WWA8344VKL Washer
General Electric WWA8344VLL Washer
General Electric WWA8350BAL Washer
General Electric WWA8350GAL Washer
General Electric WWA8350GBL Washer
General Electric WWA8354VLL Washer
General Electric WWA8354VML Washer
General Electric WWA8354VNL Washer
General Electric WWA8355BAL Washer
General Electric WWA8355GAL Washer
General Electric WWA8359VCL Washer
General Electric WWA8360BAL Washer
General Electric WWA8360GAL Washer
General Electric WWA8360GBL Washer
General Electric WWA8364VKL Washer
General Electric WWA8364VLL Washer
General Electric WWA8366LAL Washer
General Electric WWA8366LBL Washer
General Electric WWA8480BAL Washer
General Electric WWA8480GAL Washer
General Electric WWA8500GAL Washer
General Electric WWA8500GBL Washer
General Electric WWA8500GCL Washer
General Electric WWA8600GAL Washer
General Electric WWA8600GBL Washer
General Electric WWA8600GCL Washer
General Electric WWA8600RBL AUTOMATIC WASHER
General Electric WWA8600RBLAA Washer
General Electric WWA8600RBLWW Washer
General Electric WWA8600SALAA Washer
General Electric WWA8600SALWW Washer
General Electric WWA8600SBLAA Washer
General Electric WWA8600SBLWW Washer
General Electric WWA8600SCLAA Washer
General Electric WWA8600SCLWW Washer
General Electric WWA8606MAL Washer
General Electric WWA8607SALAA Washer
General Electric WWA8607SALWW Washer
General Electric WWA8607SBLAA Washer
General Electric WWA8607SBLWW Washer
General Electric WWA8607SCLAA Washer
General Electric WWA8607SCLWW Washer
General Electric WWA8608MAL Washer
General Electric WWA8608MXL Washer
General Electric WWA8610SALAA Washer
General Electric WWA8610SALWW Washer
General Electric WWA8610SBLAA Washer
General Electric WWA8610SBLWW Washer
General Electric WWA8616MAL Washer
General Electric WWA8616RBL Washer
General Electric WWA8620MAL Washer
General Electric WWA8620RBL Washer
General Electric WWA8620SALAA Washer
General Electric WWA8620SALWW Washer
General Electric WWA8620SBLAA Washer
General Electric WWA8620SBLWW Washer
General Electric WWA8620SCLAA Washer
General Electric WWA8620SCLWW Washer
General Electric WWA8630SALAA Washer
General Electric WWA8630SALWW Washer
General Electric WWA8630SBLAA Washer
General Electric WWA8630SBLWW Washer
General Electric WWA8648MAL Washer
General Electric WWA8650SALAA Washer
General Electric WWA8650SALWW Washer
General Electric WWA8650SBLAA Washer
General Electric WWA8650SBLWW Washer
General Electric WWA8657MAL Washer
General Electric WWA8657RBL Washer
General Electric WWA8666RBL AUTOMATIC WASHER
General Electric WWA8689MAL Washer
General Electric WWA8689RBL AUTOMATIC WASHER
General Electric WWA8689RBLAA Washer
General Electric WWA8689RBLWW Washer
General Electric WWA8695SALAA Washer
General Electric WWA8695SALWW Washer
General Electric WWA8695SBLAA Washer
General Electric WWA8695SBLWW Washer
General Electric WWA8700LAL Washer
General Electric WWA8700LBL Washer
General Electric WWA8800MAL Washer
General Electric WWA8800RBL
General Electric WWA8800RBLAA Washer
General Electric WWA8800RBLWW Washer
General Electric WWA8806MAL Washer
General Electric WWA8808MAL Washer
General Electric WWA8810MAL Washer
General Electric WWA8810RBL Washer
General Electric WWA8816RBL Washer
General Electric WWA8819MAL Washer
General Electric WWA8827MAL Washer
General Electric WWA8829RBLWW Washer
General Electric WWA8836MAL Washer
General Electric WWA8837RBL Washer
General Electric WWA8849RBLWW Washer
  #2 (permalink)
Old 03-15-2011, 06:02 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Unusual problem, but I think the cause is the high water pressure and I would start by putting some teflon tape on the connection and getting a pressure reduction valve on the incoming water.
__________________
  #3 (permalink)
Old 03-16-2011, 04:25 AM
Junior Member
Default New wrinkle
Quote:
Thanks for the response! Hubby forgot that the home pressure head was replaced, so replace that 34# with 50# (which I understand is just about right for home systems). We do, however, need to get the pressure reading from the water system guy at the rental's community association office - the rental is second in line of 30 from the system's pump house, so the reading there should be pretty close to what the house has (no gauge there, alas).
I'll get back with that.
  #4 (permalink)
Old 03-18-2011, 05:41 AM
Junior Member
Default
You're talking a pressure reduction valve on the line into the house, correct? Is there any such thing as a reduction valve for individual lines, like the two to the washer? House is on a slab, and we don't have much space to work with where water enters before it goes, into a wall, which is why I ask.
WatWater
  #5 (permalink)
Old 03-18-2011, 07:38 AM
Senior Expert
APP Volunteer
Default
I don't know, but unless it is impossible to get to the lines I would strongly urge you to put a PRV on the line, since you do not want to blow out a water line inside the house. Also, I would definitely use metal clad hoses on the washer and everything else.
For a short term fix you can back off pressure at the shutoff valve, but in the long term not having the shutoff valve fully open will damage it, so make it only a temporary fix.
__________________
  #6 (permalink)
Old 03-18-2011, 09:33 AM
Junior Member
Default
Thanks - already had new s.s braided hoses on machine, suspected that closing shutoff partially not a good idea. Am waiting on water guy's info, or will get a gauge myself - just to make sure the issue is pressure and not something else to investigate. Very much appreciate your help!
  #7 (permalink)
Old 03-18-2011, 10:45 AM
Senior Expert
APP Volunteer
Default
Ok, good and check your insurance to see if you are covered from a water line break, and if not, see if they provide a rider for the policy.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Not enough water pressure marshallfla Dishwasher Repair 7 05-11-2011 04:17 PM
oven temperature gets higher and higher susanshann Oven Repair (including Ranges and Cooktops) 2 02-13-2011 11:19 AM
Replacing gas hot water heater only for higher efficiency.... Olives Heating, Ventilation, and Air Conditioning (HVAC) 1 07-24-2010 05:28 AM
Gas leaking from pressure regulator jarpublic Oven Repair (including Ranges and Cooktops) 1 02-28-2009 10:19 AM
Motor humming and water comes but blades don't spin (water pressure problem?) mtheriault3 Dishwasher Repair 4 01-11-2009 04:18 PM
