| » Washer leaking during spin |
Model Number: 11027822790 Brand: Kenmore Age: 5 - 10 years
I'm getting lot of water on the floor during the spin cycles. Water seems to be coming from the front.
How do I diagnose the exact problem so that I can think about whether to fix this or not? Thank you. Ads By Google Related Models |
I looked underneath and the leak seems to happen when the pump is NOT running AND when it is running. Water appears to be coming from the hole where the metal rod from the motor enters the pump.
Will a new pump fix this? How hard is it to replace? It looks like you can just disconnect the hoses and slide a new pump on? THANK YOU for any help |
| Display Modes | |
| Maytag top loading washer leaking in spin cycle from bottom | kleve | Washer Repair | 3 | 07-23-2009 11:12 AM |
| Leaking Washer On The First Spin Cycle | SKYHAWK1 | Washer Repair | 1 | 05-11-2009 01:31 PM |
| frigidaire washer leaking during spin | Jim Thompson | Washer Repair | 0 | 03-29-2009 08:09 AM |
| GE model WJRE5500GWW leaking under washer during spin cycle... | aries47 | Washer Repair | 0 | 03-03-2009 11:26 AM |
| Leaking washer during spin cycle | Greg Mitchell | Washer Repair | 2 | 02-29-2008 04:06 AM |
