Discuss
Top load frigidair washer.How to separate transmission from tub?Trunnion screws were
 in
Washer Repair
How do I removed the transmission assembly from the tub. Trunnion screws already removed. Just can get the shaft to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top load frigidair washer.How to separate transmission from tub?Trunnion screws were
  #1 (permalink)
Old 03-11-2011, 09:11 PM
Junior Member
JOE7411 is on a distinguished road
Default Top load frigidair washer.How to separate transmission from tub?Trunnion screws were
Brand: Frigidaire   Age: 1 - 5 years
How do I removed the transmission assembly from the tub. Trunnion screws already removed. Just can get the shaft to slide out.What else needs to be removed?
  #2 (permalink)
Old 03-12-2011, 05:13 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Frigidaire has very good service manuals, so I am going to give you a link to one for your model, or a model very similar to yours.
http://frigidaireservicetips.com/pdfs/489_5.pdf
__________________
  #3 (permalink)
Old 03-13-2011, 04:36 PM
Junior Member
Default
Thank you very much for your help.
  #4 (permalink)
Old 03-13-2011, 04:45 PM
Senior Expert
APP Volunteer
Default
Glad to do it, good luck!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidair Washer leaking HelenofTrout Washer Repair 5 12-14-2011 12:31 AM
Coupler Or Transmission On Sears Top Load Washer CobaltSmith Washer Repair 5 11-12-2010 02:01 PM
(Top-Load) Play in Transmission Gear peterabcd Washer Repair 0 06-04-2010 04:05 AM
Frigidair washer scribkr Washer Repair 1 03-08-2010 02:46 PM
GE top load washer, possible transmission? AmandaWest Washer Repair 5 11-16-2009 03:45 PM
