I had the pressure switch replaced on my washer. The first load after it was fixed the washer overflowed again, the repair company came out said I had set the washer to reset and thats why it overflowed. But when they went to fill the super load it overflowed on them also. They went on to repair something but still blamed it on the reset. I have set it on reset twice now it has not overflown. I belive the repair was done incorrectly the first time. any answeres
Check the pressure tube that runs to the new switch, also check where the tube attaches to the tub, sometimes the tube will get some crud in it.:)
