can not read the model number have tried and tried
My 6-8 year old whirlpool top loading washing machien has taken a couple times to spin things the last couple weeks. then it stopped spinning completely. Help. turns on washes..runs full cycle will not spin..water drains out
If you will post a model number someone may be able to help you.
If this is a direct drive Whirlpool check the clutch. See the Sticky at the top of this page on Direct Drive brakes.
Originally Posted by: agentdee@aol.com can not read the model number have tried and tried
My 6-8 year old whirlpool top loading washing machien has taken a couple times to spin things the last couple weeks. then it stopped spinning completely. Help. turns on washes..runs full cycle will not spin..water drains out check the lid switch
If the water is draining out it is not the lid switch.
