Hello,
I did a load of wash this morning. I put those clothes in the dryer and pressed start on the washing maching to begin the fill process. The "wash" light comes on but the "fill" light flashes quickly, does not stay on and the washer does not fill.
I power cycled the washer, turned the electric breaker on and off, disconnected the fill hoses and the drain hose, and disconnected the power. I took the control panel off, and there is a diagram and some instructions on how to check error codes. I believe the errors are "slow pump, push button and pump". What part(s) do you think I need to replace?
Thanks, Lori
See if there are error codes from a flashing light on the motor. Here is a site that will tell you how to interpret the codes. Try resetting the machine first. HydroWave GE Washer Repair Guide
