davjulcos
#1 Posted : Thursday, March 10, 2011 8:06:42 AM(UTC)
davjulcos
My Amana washer spins but my clothes are coming out wet and they take forever to dry. Is it the pump? Any advice would be greatly appreciated.:confused:
magician59
#2 Posted : Thursday, March 10, 2011 9:24:47 AM(UTC)
magician59
We may be able to help you, if you can provide the model number.
davjulcos
#3 Posted : Friday, March 11, 2011 8:51:14 AM(UTC)
davjulcos
Nav5805aww
magician59
#4 Posted : Friday, March 11, 2011 9:35:12 AM(UTC)
magician59
First, I would inspect the drain hose for any kinks or obstructions. Also the pump. If it appears to be pumping out the water in a reasonably strong stream, check to see if it is spinning as fast as you're used to seeing it spin.
I would suspect that the problem is either a restricted drain hose, or a worn thrust bearing. The thrust bearing is responsible for releasing the brake, so the basket can spin. As the bearing wears, the brake is not allowed to fully release, and can drag, causing a slow spin.
Part number: AP4009132
davjulcos
#5 Posted : Friday, March 11, 2011 1:53:09 PM(UTC)
davjulcos
Thanks for the help. I will check it this weekend.
davjulcos
#6 Posted : Friday, March 11, 2011 1:54:47 PM(UTC)
davjulcos
Is this a difficult repair?
magician59
#7 Posted : Sunday, March 13, 2011 6:48:32 AM(UTC)
magician59
It's involved and a bit frustrating, but well within the ability of most mechanically-inclined persons.
iowncars
#8 Posted : Wednesday, October 10, 2012 1:39:09 PM(UTC)
iowncars
I have the exact model washer and mine has the exact problem. Anyone know of the sure fix? What part number is needed?
Water is left in washer, door is locked cannot open, does not drain, clothes still wet (Washer Repair)
by Guest 12/4/2022 11:52:36 AM(UTC)
kenmore he2 clothes still wet (Washer Repair)
by ldenorio 2/9/2020 2:55:08 PM(UTC)
Crosley Washer (Whirlpool) not spinning fast enough, clothes still wet (Washer Repair)
by Cajun Girl 12/5/2018 12:12:13 PM(UTC)
clothes still wet after cycle spin (Washer Repair)
by biho 12/25/2015 8:35:07 PM(UTC)
Spins but clothes still wet (Washer Repair)
by tom rosser 8/11/2014 10:59:53 AM(UTC)
Maytag top load - drains & spins but clothes still wet (Washer Repair)
by Liz459 3/24/2013 4:26:14 PM(UTC)
clothes still wet after 1st spin cycle but dry after 2nd spin cycle (Washer Repair)
by sscaduto 11/10/2012 1:28:37 PM(UTC)
Clothes still wet after spin cycle (Washer Repair)
by gbdad10 3/31/2012 3:35:25 PM(UTC)
Clothes still wet after spin (Washer Repair)
by Ranger25 7/24/2011 2:43:22 PM(UTC)
Maytag stackable SG7800 clothes still wet at end (Washer Repair)
by smr277 10/9/2010 10:12:31 PM(UTC)
Clothes still WET after final spin (Washer Repair)
by HandyHubby1963 7/2/2010 7:00:52 AM(UTC)
by Rheinking 4/30/2010 11:19:45 AM(UTC)
Clothes still wet (Washer Repair)
by pnowacki 1/15/2010 6:38:18 PM(UTC)
Neptune washer spins and pump working but clothes still wet (Washer Repair)
by lanehi 10/25/2009 4:07:25 AM(UTC)
by PTJT5 9/27/2009 8:55:52 AM(UTC)
