Washer stops during rinse cycle with f1 code. Have to push Pause/Cancel button, then push Start alternately several times before washer will continue on its merry way. Adding several gallons of water while the lid is open during the pause will decrease the number of times I have to cycle the P/C and Start buttons. Water hoses and screens are clear. No restriction of water flow. The problem seems to be electronic rather than mechanical. Would appreciate any and all suggestions from other consumers, technicians, parts person(s), manufacturer's representatives, salespersons, electricians, mechanics, or anyone else that can help. THANK YOU!
