| » Washer sounds like a helicopter |
Did anyone ever remedy this? Mine is doing the same thing
I have a Kenmore HE 5t Elite, only 2 yrs old, sounds like an aircraft taking off every spin cycle. I checked in to it did not stop til I got an answer.
I am a woman you don't want to fool with. Turns out on these machines the rear tub bearings/ spin basket support give out. It is a manufacturing issue and at least on mine, I have a ten yr warranty on the tub or basket , whatever you want to call it. the whole tubbasket needs replaced because of how the bearings were manufactured into the tub. sucks, really sucks! I guess it could be worse. Hope that helps some of you. |
naners,
Yours is a front load model, the Oasis is a top load model, they are very different in construction. Should you be interested in what I believe causes the failure of the spiders in these machines please visit the thread on this site: - Spider Corrosion And Foul Odours In Front Load Washers |
Quote:
to the rest of you, I was being helpful. I know the problem with my machine and it is getting fixed. forthose of us who have "FRONT LOADERS" there is a mnaufacturing issue in the rear tub bearings. |
To naners,
The original post in this thread refers to an 'Oasis', a top load model. Reading your post I concluded that you were identifying your front loader as being similar to the original subject of the thread. Should I be in error I apologise. Whilst you may well be aware of the current fault on your machine, are you aware of what may of caused these faults? Should you be, that is why I suggested the thread I did. Should you have no interest so be it. |
| Display Modes | |
| Maytag Washer Sounds Like a Airplane | sue1230 | Washer Repair | 1 | 07-17-2010 03:39 PM |
| Final spin sounds like a helicopter | tochenduszko | Washer Repair | 14 | 07-11-2010 09:53 PM |
| Whirlpool Gold Accubake Wall Oven - Sounds like a helicopter | mszwarc5 | Oven Repair (including Ranges and Cooktops) | 1 | 02-16-2010 04:32 AM |
| washer sounds like a plane taking off! | AS Carroll | Washer Repair | 5 | 12-10-2009 02:20 AM |
| Sounds like there is something in the washer | pkharris@cox.net | Washer Repair | 1 | 07-09-2008 03:41 PM |
