Discuss
Maytag Neptune Washer model # mah5500bww
 in
Washer Repair
We have had this washer for a period of about 4 years or more and have had nothing but trouble.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune Washer model # mah5500bww
  #1 (permalink)
Old 10-22-2007, 02:00 PM
Scotty Scotty is offline
Junior Member
Scotty is on a distinguished road
Default Maytag Neptune Washer model # mah5500bww
We have had this washer for a period of about 4 years or more and have had nothing but trouble. They have changed one unit right after another.
What it is doing is when you set it to wash and rinse cold it will run cold sometimes for wash but will run hot on rinse and vice versa. We have changed hoses and have set it to run in reverse such as if you want cold set it to hot in which works sometimes. Also on the detergent dispenser it quit working and I have cleaned it with no success. I have heard that there is a valve that goes bad
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-22-2007, 05:29 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Scotty
Your washer (including all water valves) operates by the main control board. Most likely the problem is there and it has to be replaced.
- The part number for the new main control board AP3672586
- Here are the break down diagrams for the Maytag Neptune washer Model MAH5500BWW
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Help Needed - LR code vtcyclist Washer Repair 2 11-14-2007 10:59 AM
Mah3000aww Maytag Neptune/bearings,leak Tinamd Washer Repair 0 10-01-2007 11:30 AM
Maytag Neptune LarryC Washer Repair 2 09-29-2007 08:56 PM
Maytag Neptune Clothes washer AnnieB Washer Repair 1 09-19-2007 05:03 AM
Maytag Neptune Washer utep42 Washer Repair 1 08-31-2007 04:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
