Discuss
My washer makes a clicking noise in the wash and spin cycle ,won't m/t
 in
Washer Repair
My Washer started out by not washing on the low wash cycle but would work fine in the high speed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » My washer makes a clicking noise in the wash and spin cycle ,won't m/t
  #1 (permalink)
Old 12-28-2008, 04:15 PM
Junior Member
bowlke is on a distinguished road
Default My washer makes a clicking noise in the wash and spin cycle ,won't m/t
Model Number: 11-26822690   Brand: Kenmore   Age: 5 - 10 years
My Washer started out by not washing on the low wash cycle but would work fine in the high speed cycle,in the low speed cycle it makes a clicking sound and it also hums, now in the spin cycle it does the same thing and won't m/t out the water and makes the same clicking sound and hum.
Ads By Google
Related Models
Frigidaire 11-2969-00-01 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-02 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-03 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-04 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-05 Tap(v1) / Wall Oven
Amana 11-2C Room Air Conditioner
Amana 11-2CH Room Air Conditioner
Amana 11-2D Room Air Conditioner
Amana 11-2G Room Air Conditioner
Amana 11-2GM Room Air Conditioner
Amana 11-2J Room Air Conditioner
Amana 11-2JM Room Air Conditioner
Amana 11-2MW Room Air Conditioner
Amana 11-2N Room Air Conditioner
Amana 11-2NM Room Air Conditioner
Amana 11-3C Room Air Conditioner
Amana 11-3CH Room Air Conditioner
Amana 11-3D Room Air Conditioner
Amana 11-3DH Room Air Conditioner
Frigidaire 11-4173-00-03 Tap(v1) / Electric Range
Frigidaire 11-4369-00-01 Tap(v1) / Wall Oven
Frigidaire 11-4369-00-02 Tap(v1) / Wall Oven
Frigidaire 11-4373-00-03 Tap(v1) / Electric Range
Frigidaire 11-4969-00-01 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-02 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-03 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-04 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-05 Tap(v1) / Electric Wall Oven
Frigidaire 11-4989-00-01 Tap(v1) / Wall Oven
Frigidaire 11-4989-00-03 Tap(v1) / Wall Oven
Frigidaire 11-4989-00-04 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-01 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-02 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-03 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-04 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-05 Tap(v1) / Electric Wall Oven
Amana 11-5C Room Air Conditioner
Amana 11-5CH Room Air Conditioner
Amana 11-5D Room Air Conditioner
Amana 11-5DH Room Air Conditioner
Amana 11-5G Room Air Conditioner
Amana 11-5GH Room Air Conditioner
Amana 11-5J Room Air Conditioner
Amana 11-5JH Room Air Conditioner
Frigidaire 11-6553-00-04 Tap(v6) / Electric Oven
Frigidaire 11-6553-23-04 Tap(v7) / Electric Oven
Frigidaire 11-6553-45-04 Tap(v8) / Electric Oven
Frigidaire 11-6553-57-04 Tap(v9) / Electric Oven
Frigidaire 11-6553-66-04 Tap(v10) / Electric Oven
Frigidaire 11-6559-00-01 Tap(v2) / Wall Oven
Frigidaire 11-6653-00-04 Tap(v6) / Electric Oven
Frigidaire 11-6653-23-04 Tap(v7) / Electric Oven
Frigidaire 11-6653-45-04 Tap(v8) / Electric Oven
Frigidaire 11-6653-57-04 Tap(v9) / Electric Oven
Frigidaire 11-6653-66-04 Tap(v10) / Electric Oven
Frigidaire 11-7439-00-01 Tap(v2) / Wall Oven
Frigidaire 11-7969-00-01 Tap(v2) / Wall Oven
Frigidaire 11-8969-00-01 Tap(v2) / Wall Oven
Frigidaire 11-9173-00-03 Tap(v2) / Electric Range
Frigidaire 11-9373-00-03 Tap(v2) / Electric Range
Frigidaire 11-9969-00-01 Tap(v2) / Wall Oven
Amana 110
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
  #2 (permalink)
Old 12-29-2008, 01:44 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Check for a broken motor coupler; also check for obstruction in the pump.
  #3 (permalink)
Old 12-30-2008, 04:18 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If it works in high speed but not low, I would check the timer for burnt contacts, just pull the cover off if it is metal.
If ok, I would pull off the outer panel and check the motor for overheating in slow speed operation.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
timer makes clicking noise washer won't agitate or spin gman4psu Washer Repair 0 11-27-2009 06:40 AM
Washer makes clunking noise during wash cycle EAS Washer Repair 5 10-01-2009 04:59 PM
Washer makes clunking noise during wash cycle EAS Dryer Repair 0 09-29-2009 10:08 AM
Washer makes a loud clicking noise on spin cycle pattihanni Washer Repair 0 05-02-2009 09:40 AM
washer makes noise in spin cycle Jamesandloretta Washer Repair 2 03-24-2008 04:25 PM
