| » Kenmore Front Load Washer Vibration |
Model Number: 970-C42062-00 Brand: Kenmore Age: 5 - 10 years
My washer is not quite 6 years old. Just replaced the drain pump a month ago. Today the washer started vibrating during spin cycle. The vibration increases with speed. The problem is there with or without a load in the drum. The springs look okay and the the shock absorbers are also working okay. I removed all panels and checked the rear during spin operation. The pulley appears to be out of round. When I removed it and placed it on a flat surface it is not completely flush with the surface. The bearing looks fine. Is it possible the pulley is unbalanced and causing this problem? The ribbed belt also appeared to have moved out of position by a thread or two on the drive motor guide. When I repositioned the belt to where it looked like it should be there was no change in the vibration. Any advice would be appreciated.
| Display Modes | |
| Kenmore Front Load Washer HE 4t | Ladpol | Washer Repair | 1 | 02-14-2010 06:48 AM |
| Kenmore Front Load Washer Won't Run | nsmslf4 | Washer Repair | 0 | 02-09-2010 07:11 AM |
| Kenmore Elite Front Load Washer | Jo Baker | Washer Repair | 0 | 08-22-2009 10:30 AM |
| Kenmore Front Load Washer 4Ht | hvaliquette | Washer Repair | 1 | 02-12-2009 03:39 AM |
| kenmore front load washer | mattsea | Washer Repair | 1 | 01-11-2009 02:29 PM |
