I Have A Kenmore Tumble Action Washer That Has A Loose Spin Basket And Makes Noise When Spinning. I Have Checked The Springs And Shockes And All Apprear To Be Ok. Is The Basket Held In Place By A Bearing That May Have Worn Out And Needs Replacing? What Are Your Thoughts?
Very common problem. Sounds like a worn out bearing to me.
How Hard Is It To Replace The Bearing And Is There A Manual Or Guide Available?
What's the full model number?
