Discuss
Roper Top Load Repair Question
 in
Washer Repair
I have a Roper Top Load Washer Model # RAX4233PQO, It filled up with water and then stopped working. It
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper Top Load Repair Question
  #1 (permalink)
Old 03-08-2011, 08:28 AM
Junior Member
B Robinson is on a distinguished road
Default Roper Top Load Repair Question
Model Number: RAX4233PQ0   Brand: Roper   Age: 5 - 10 years
I have a Roper Top Load Washer Model # RAX4233PQO, It filled up with water and then stopped working. It acts like it is getting no power. The outlet that it is plugged into is fine. I have moved the knob to different cycles, but it will do nothing. Thanks
Related Models
Roper RAX4233PQ0 AUTOMATIC WASHER
Maytag RAX5000AXB MISC / ACCESSORY
Maytag RAX5000CXB MISC / ACCESSORY
Maytag RAX5100AXB MISC / ACCESSORY
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Roper RAX5133AL1 AUTOMATIC WASHER
Roper RAX5133AW0 Washers*
Maytag RAX5200AXB MISC / ACCESSORY
Maytag RAX5200CXB MISC / ACCESSORY
Maytag RAX5300AXB MISC / ACCESSORY
Maytag RAX5400AXB MISC / ACCESSORY
Maytag RAX5500AXB MISC / ACCESSORY
Maytag RAX5500CXB MISC / ACCESSORY
Maytag RAX5600AXB MISC / ACCESSORY
Maytag RAX5700AXB MISC / ACCESSORY
Maytag RAX5700CXB MISC / ACCESSORY
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Roper RAX7244EN0 WASHER
Roper RAX7244EN1 WASHER
Roper RAX7244EQ0 WASHER
Roper RAX7244EQ1 WASHER
Roper RAX7244EW0 WASHER
Roper RAX7244EW1 WASHER
Roper RAX7244JQ0 WASHER
Roper RAX7244KQ0 WASHER
Roper RAX7244KQ1 AUTOMATIC WASHER
Roper RAX7244KQ2 AUTOMATIC WASHER
Roper RAX7244PQ0 AUTOMATIC WASHER
Roper RAX7244PQ1 AUTOMATIC WASHER
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Roper RAX7245AW0 Washers*
Roper RAX7245BL1 AUTOMATIC WASHER
Roper RAX7245BQ1 AUTOMATIC WASHER
Roper RAX7245BW0 DIRECT-DRIVE AUTOMATIC WASHER
Roper RAX7245BW1 AUTOMATIC WASHER
Roper RAX7245JQ0 WASHER
Roper RAX7245KQ0 WASHER
Roper RAX7245KQ1 AUTOMATIC WASHER
Whirlpool RB1000XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYN3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN5 24" ELECTRIC OVEN
Whirlpool RB1005XYW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW5 24" ELECTRIC OVEN
Whirlpool RB100PXK-0 24" ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK0
Whirlpool RB100PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB100PXYB3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB5 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1200XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB3 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB5 24" ELECTRIC OVEN
Whirlpool RB1300XKW1 COOKTOP
Frigidaire RB130FA0 Frg(v5) / Electric Range
Frigidaire RB130FF0 Frg(v4) / Electric Range
Frigidaire RB130FH0 Frg(v6) / Electric Range
Frigidaire RB130FL0 Frg(v3) / Electric Range
Frigidaire RB130FM0 Frg(v2) / Electric Range
Frigidaire RB130FW0 Frg(v1) / Electric Range
Whirlpool RB130PXK0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK2 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV4 BUILT IN DOUBLE OVEN
Frigidaire RB131CA0 Frg(v1) / Electric Cooktop
Frigidaire RB131CA1 Frg(v1) / Built - in Electric Cooktop
Frigidaire RB131CF0 Frg(v2) / Electric Cooktop
Frigidaire RB131CF1 Frg(v2) / Built - in Electric Cooktop
Frigidaire RB131CH0 Frg(v3) / Electric Cooktop
Frigidaire RB131CH1 Frg(v3) / Built - in Electric Cooktop
Frigidaire RB131CL0 Frg(v4) / Electric Cooktop
Frigidaire RB131CL1 Frg(v4) / Built - in Electric Cooktop
Frigidaire RB131CM0 Frg(v5) / Electric Cooktop
Frigidaire RB131CM1 Frg(v5) / Built - in Electric Cooktop
Frigidaire RB131CW0 Frg(v6) / Electric Cooktop
Frigidaire RB131CW1 Frg(v6) / Built - in Electric Cooktop
Frigidaire RB131NL1 Frg(v2) / Electric Range
Frigidaire RB131NL2 Frg(v3) / Electric Cooktop Range
Frigidaire RB131NL3 Frg(v6) / Electric Cooktop Range
Frigidaire RB131NM1 Frg(v3) / Electric Range
Frigidaire RB131NM3 Frg(v4) / Electric Cooktop Range
Frigidaire RB131NW1 Frg(v1) / Electric Range
Frigidaire RB131NW2 Frg(v2) / Electric Cooktop Range
Frigidaire RB131NW3 Frg(v5) / Electric Cooktop Range
Frigidaire RB136CDB0 Frg(v1) / Electric Range
  #2 (permalink)
Old 03-10-2011, 06:17 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
First place to check is the lid switch. If that is not the problem, tell us what you found out, and if the machine will drain if you move the timer to the end of the wash or rinse cycle.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Dryer takes more than one cycle to dry a load Acidburn13579 Dryer Repair 1 06-01-2009 04:26 AM
roper stove code repair question hillesla Oven Repair (including Ranges and Cooktops) 0 05-07-2008 01:32 PM
maytag front load question ljkase Washer Repair 1 04-22-2008 06:40 PM
Roper Dryer question bjr Dryer Repair 1 12-06-2007 06:50 AM
roper washer question whitehanes34 Washer Repair 2 12-02-2007 12:03 PM
