Machine is 14 months old. In the middle of a load it stopped with 13 minutes left. Panel read "Ld". This has happened before, I moved the load around and it restarted. This code appeared after washing towels or rugs. I figured it was not balanced. This time it was a smaller load and will not do anything after I rearranged the load. Water is still in washer about an inch deep. Tried unplugging machine. Wouldn't reset. The code "Po" has also appeared on the panel. It will read 47 minutes and appear to be a normal cycle set but will not start.
