Discuss
Washer Slow Fill On Cold
 in
Washer Repair
Mt Whirlpool Mod#lsr5132pq,fills Fine On Hot Water It Starts Fine On Cold Then Slows To Trickle. It Does The Same
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Slow Fill On Cold
  #1 (permalink)
Old 12-27-2008, 08:44 PM
Junior Member
sdrtgr is on a distinguished road
Default Washer Slow Fill On Cold
Brand: Whirlpool   Age: 1 - 5 years
Mt Whirlpool Mod#lsr5132pq,fills Fine On Hot Water It Starts Fine On Cold Then Slows To Trickle. It Does The Same On The Rinse Cycle.
  #2 (permalink)
Old 01-23-2012, 11:15 AM
Junior Member
Zandra is on a distinguished road
Default whirlpool washer
Whirlpool Mod#gsq9344eq0,fills Fine On Hot Water It Starts Fine On Cold Then Slows To Trickle. It Does The Same On The Rinse Cycle. What part would I need to change.
  #3 (permalink)
Old 01-25-2012, 08:04 PM
Junior Member
wineguy51 is on a distinguished road
Default
I would be looking at the supply line for kinks or obstruction in the hose. Disconnect the supply line from the back of the washer and check the screen for debris. While the hose is disconnected, put the hose in a bucket and turn on the valve to check your flow.
Steve
  #4 (permalink)
Old 01-25-2012, 08:12 PM
Junior Member
Default
Thank you.....I will check that.
  #5 (permalink)
Old 04-03-2012, 05:46 PM
Junior Member
billrd01 is on a distinguished road
Default
Quote:
Steve
I have same problem - water pressure at washer end of each hose is fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Slow Fill markstl Washer Repair 5 08-12-2010 05:36 PM
Maytag topload washer slow to fill allie33 Washer Repair 1 04-20-2009 11:05 AM
Slow cold water fill skirven2 Washer Repair 1 04-25-2008 10:17 PM
maytag washer wiil fill slow on spin cycle sancortez Washer Repair 0 04-11-2008 06:34 PM
Washer is slow to fill Dbowls Washer Repair 1 08-30-2007 02:22 PM
