Discuss
Chlorine leaking
 in
Washer Repair
Only use the chlorine dispenser once every 3-4 weeks as the kids are now all gone. Did a load last
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Chlorine leaking
  #1 (permalink)
Old 03-07-2011, 09:00 AM
Junior Member
sesser is on a distinguished road
Default Chlorine leaking
Model Number: MAV7580EWW Top Loader   Brand: Maytag   Age: 5 - 10 years
Only use the chlorine dispenser once every 3-4 weeks as the kids are now all gone. Did a load last night and added the chlorine into the chlorine dispenser. When load was done, I noted what appeared to be a small puddle of water on the floor. When I wiped it up with an old dish towel, it was obviously chlorine as the color of the dish towel bleached out. Today I poured a cup of water into the chlorine dispenser to see if it would leak, and it did not.
Any thoughts? Suggestions?
Sesser
Ads By Google
Related Models
International MAV7600ACQ Washer - Top Loading
International MAV7600AGW Washer - Top Loading
Maytag MAV7600AWQ Washer, Atlantis
Maytag MAV7600AWW Washer, Atlantis
International MAV7600BGW Washer - Top Loading
International MAV7600CGW Washer - Top Loading
Maytag MAV7650AWQ Washer, Atlantis
Maytag MAV7650AWW Washer, Atlantis
Maytag MAV7657EWQ Washer, Atlantis
Maytag MAV7657EWW Washer, Atlantis
Maytag MAV7700AWQ Washer, Atlantis
Maytag MAV7700AWW Washer, Atlantis
International MAV7750AGW Washer - Top Loading
International MAV7750BGW Washer - Top Loading
International MAV7750CGW Washer - Top Loading
Maytag MAV7757AWQ Washer, Atlantis
Maytag MAV7757AWW Washer, Atlantis
Maytag MAV8000AWQ Washer, Atlantis
Maytag MAV8000AWW Washer, Atlantis
Maytag MAV8057AWQ Washer, Atlantis
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
Maytag MAV8551AWW Washer, Atlantis
Maytag MAV8557AWQ Washer, Atlantis
Maytag MAV8557AWW Washer, Atlantis
Maytag MAV8600AWQ Washer, Atlantis
Maytag MAV8600AWW Washer, Atlantis
Maytag MAV8601AWQ Washer, Atlantis
Maytag MAV8601AWW Washer, Atlantis
Maytag MAV8757AWQ Washer, Atlantis
Maytag MAV8757AWW Washer, Atlantis
Maytag MAV9501EWQ Washer, Atlantis
Maytag MAV9501EWW Washer, Atlantis
Maytag MAV9504EWQ Washer, Atlantis
Maytag MAV9504EWW Washer, Atlantis
Maytag MAV9557EWQ Washer, Atlantis
Maytag MAV9557EWW Washer, Atlantis
Maytag MAV9600EWQ Washer, Atlantis
Maytag MAV9600EWW Washer, Atlantis
Maytag MAV9657EWQ Washer, Atlantis
Maytag MAV9657EWW Washer, Atlantis
Maytag MAV9750AGW Washer, Atlantis
Maytag MAV9750AWQ Washer, Atlantis
Maytag MAV9750AWW Washer, Atlantis
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
  #2 (permalink)
Old 03-09-2011, 10:42 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I am not sure if this is relevant to your problem, but Maytag has re-designed the dispenser (they do that a lot). Here is the info from their tech bulletin
Order new detergent dispenser
22003797. Replace old dispenser with new
dispenser having a re-designed nozzle clip. The nozzle clip collects residual detergent in the spout area and puts it into the water before the machine ends the cycle. Use the existing torsion rod and retainers not included with the replacement dispenser. For new installations, or to replace entire kit, order “Detergent Dispenser Kit”
22003796. The “Detergent Dispenser Kit” contains the new dispenser with the re-designed nozzle clip. Note: The re-designed nozzle clip is not interchangeable with the original detergent dispenser.
APP does not list this part as available, so I would call them and see what they say and recommend. (Those of us who reply do not work for APP and are not associated with their parts operations, so unless we are very familiar with a part we are not much good in talking about specific parts)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oil leaking gp3002 Washer Repair 1 10-20-2009 04:19 PM
12 yr old GE leaking dhmusic Dishwasher Repair 1 10-20-2009 10:39 AM
icemaker was leaking so I replaced it. Still leaking Laurie Refrigerator & Freezer Repair 1 03-22-2008 09:24 AM
Air Gap Leaking Big Guy Dishwasher Repair 3 01-07-2008 03:48 PM
