Discuss
washer leak
 in
Washer Repair
Washer overfills when on the highest (super) level. We watched it by taking off the front panel and running a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer leak
  #1 (permalink)
Old 03-06-2011, 03:00 PM
Junior Member
jeerlinger is on a distinguished road
Question washer leak
Model Number: wjrr417051 ww   Brand: GE   Age: 1 - 5 years
Washer overfills when on the highest (super) level. We watched it by taking off the front panel and running a load. Also the air pressure dome has a lot of mold inside and seems to need a cleaning. The water overflows through a plastic tube down into the floor of the machine.
Maybe the air dome needs to be cleaned out?
Related Models
General Electric WJRR4170E0CC Washer
General Electric WJRR4170E0WW Washer
General Electric WJRR4170E1CC Washer
General Electric WJRR4170E1WW Washer
General Electric WJRR4170E3CC Washer
General Electric WJRR4170E3WW Washer
General Electric WJRR4170E4CC Washer
General Electric WJRR4170E4WW Washer
General Electric WJRR4170E5CC Washer
General Electric WJRR4170E5WW Washer
General Electric WJRR4170E6CC Washer
General Electric WJRR4170E6WW Washer
General Electric WJRR4170G0WW Washer
General Electric WJRR4170G1WW WASHER
General Electric WJRR4170G2WW WASHER
General Electric WJRR4170G3WW WASHER
General Electric WJRR4170G4WW WASHER
General Electric WJRR4170G5WW WASHER
General Electric WJRR4170G6WW WASHER
General Electric WJSE3110A0AA Washer
General Electric WJSE3110A0CC Washer
General Electric WJSE3110A0WW Washer
General Electric WJSE3110A2CC Washer
General Electric WJSE3110A2WW Washer
General Electric WJSE4150B0CC Washer
General Electric WJSE4150B0WW Washer
General Electric WJSE4150B1CC Washer
General Electric WJSE4150B1WW Washer
General Electric WJSE4150B2CC Washer
General Electric WJSE4150B2WW Washer
General Electric WJSE4150B3CC Washer
General Electric WJSE4150B3WW Washer
General Electric WJSR1070A1AA Washer
General Electric WJSR1070A1CC Washer
General Electric WJSR1070A1WW Washer
General Electric WJSR1070A2AA Washer
General Electric WJSR1070A2WW Washer
General Electric WJSR2070B0CC Washer
General Electric WJSR2070B0WW Washer
General Electric WJSR2070B2CC Washer
General Electric WJSR2070B2WW Washer
General Electric WJSR2070B3CC Washer
General Electric WJSR2070B3WW Washer
General Electric WJSR2070B4CC Washer
General Electric WJSR2070B4WW Washer
General Electric WJSR2070B9WW WASHER
General Electric WJSR2070D0WW Washer
General Electric WJSR2070D1WW Washer
General Electric WJSR2070D2WW Washer
General Electric WJSR2070D3WW Washer
General Electric WJSR2070D5WW Washer
General Electric WJSR2070D6WW Washer
General Electric WJSR2080T2AA Washer
General Electric WJSR2080T2WB Washer
General Electric WJSR2080T2WW Washer
General Electric WJSR2080T3AA Washer
General Electric WJSR2080T3WB Washer
General Electric WJSR2080T3WW Washer
General Electric WJSR2080T5AA Washer
General Electric WJSR2080T5WB Washer
General Electric WJSR2080T5WW Washer
General Electric WJSR2080T6AA Washer
General Electric WJSR2080T6WB Washer
General Electric WJSR2080T6WW Washer
General Electric WJSR2080T8AA Washer
General Electric WJSR2080T8WB Washer
General Electric WJSR2080T8WW Washer
General Electric WJSR2080TAAA Washer
General Electric WJSR2080TAWB Washer
General Electric WJSR2080TAWW Washer
General Electric WJSR2080V1AA Washer
General Electric WJSR2080V1WW Washer
General Electric WJSR2080V2AA Washer
General Electric WJSR2080V2WW Washer
General Electric WJSR2080V3AA Washer
General Electric WJSR2080V3WW Washer
General Electric WJSR4160D0CC Washer
General Electric WJSR4160D0WW Washer
General Electric WJSR4160D2CC Washer
General Electric WJSR4160D2WW Washer
General Electric WJSR4160D5CC Washer
General Electric WJSR4160D5WW Washer
General Electric WJSR4160D6CC Washer
General Electric WJSR4160D6WW Washer
General Electric WJSR4160DACC Washer
General Electric WJSR4160DAWW Washer
General Electric WJSR4160DCCC Washer
General Electric WJSR4160DCWW Washer
General Electric WJSR4160G0WW Washer
General Electric WJSR4160G1WW WASHER
General Electric WJSR4160G2WW WASHER
General Electric WJSR4160G3WW WASHER
General Electric WJSR4160G4WW WASHER
General Electric WJSR4160G5WW WASHER
General Electric WJSR4160G6WW WASHER
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" ELECTRIC RANGE CERAN COOKTOP
General Electric WKRE5500K0WW WASHER
General Electric WKRE5550K0WW WASHER
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
General Electric WKSE6280B1WW Washer
General Electric WKSE6280B2WW Washer
  #2 (permalink)
Old 03-07-2011, 09:42 AM
Senior Member
applianceman is on a distinguished road
Default
Look in the pressure tube to see if it is clogged and if so clean it out and it should be fixed. Also make sure the nipple that the tub connects to isn’t clogged.
Watch the washer during spin and if the spin basket spins during wash then the brakes are bad and the transmission will have to be replaced.
If the tube isn’t clogged and the spin doesn’t turn in wash then you either have a bad water valve or a bad pressure switch. When the washer is running water turn the washer off repeatedly to see if the water stops each time. If the water continues to run when you turn the washer off then the water valve is bad and if the water stops each time the water pressure switch is bad.
One more thing, if the washer has too much suds then water will come out of that overflow tube. When the washer is leaking look in the washer to see if there is an excessive amount of suds. If so either cut down on the amount of detergent or change detergent brands.
Washer Repair Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer leak npl Washer Repair 1 11-11-2010 12:29 PM
washer leak longhaulamerica Washer Repair 1 07-22-2010 12:17 PM
Washer Leak jennimcknight Washer Repair 0 06-02-2010 08:03 AM
GE washer leak. Why? 5december Washer Repair 2 09-12-2009 07:38 PM
leak on ge washer shopower Washer Repair 2 12-09-2007 02:30 AM
