Discuss
Washer agitates normal then slows down and stops.
 in
Washer Repair
I have a GE WJSE3110AOWW washer. It works fine until it gets to the 6 minute cycle. Once inside the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer agitates normal then slows down and stops.
  #1 (permalink)
Old 10-21-2007, 02:29 PM
jnaylor jnaylor is offline
Junior Member
jnaylor is on a distinguished road
Default Washer agitates normal then slows down and stops.
Model Number: WJSE3110AOWW   Brand: GE   Age: 5 - 10 years
I have a GE WJSE3110AOWW washer. It works fine until it gets to the 6 minute cycle. Once inside the 6 minute cycle it agitates normal for a short while and suddenly slows down so that it barely agitates and eventually stops. It stays this way until this cycle is complete and then continues normally through the rest of the wash.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-22-2007, 03:56 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
See if this happens during a different timer cycle.
__________________
  #3 (permalink)
Old 10-22-2007, 09:55 AM
Junior Member
Default
No, it doesn't. Just in the 6 minute cycle.
  #4 (permalink)
Old 10-22-2007, 08:14 PM
Senior Expert
APP Volunteer
Default
Then that confirms a bad timer; I would pull the cover off and verify burnt contacts. Just click on your model # to get parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer agitates but wont spin maddness35 Washer Repair 3 11-14-2008 06:05 AM
Kitchen Aid Washer Agitates But Won't Spin leroypg Washer Repair 1 10-16-2007 05:01 PM
washer agitates but won't spin` mls6089 Washer Repair 0 10-12-2007 09:34 AM
I can hear water behind the drum is this normal? repowoman Washer Repair 0 10-06-2007 01:58 PM
Washer barely agitates, won't drain or spin jsc2010 Washer Repair 4 09-12-2007 03:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
