Discuss
Motor intermittent
 in
Washer Repair
Hi I have a problem with the relay of the motor sometimes works intermittent could it be a switch mtr
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Motor intermittent
  #1 (permalink)
Old 10-21-2007, 12:54 PM
spis spis is offline
Junior Member
spis is on a distinguished road
Default Motor intermittent
Model Number: KAWS75OGQ1   Brand: Kitchen Aid   Age: 1 - 5 years
Hi I have a problem with the relay of the motor sometimes works intermittent could it be a switch mtr problem or the motor?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-22-2007, 03:55 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull front panel and check the motor connector, you might have a burnt pin. If ok, check your timer connector pins for a bad connection.
When the washer becomes intermittent, move the timer to another cycle, if now ok, you probably have a bad timer.
__________________
  #3 (permalink)
Old 10-22-2007, 12:42 PM
Junior Member
Default
The conectors are ok The washer fill water ok but when starts to wash the motor's relay work intermittent, then I turn the timer mannually, yust a little, and it works all the cycle then drain ok and in the spin cycle agan intermittent, the lid switch is ok, I can see some sparkle in the switch mtr of the motor
  #4 (permalink)
Old 10-22-2007, 04:50 PM
Senior Expert
APP Volunteer
Default
Seems like a bad timer. I usually confirm by pulling cover off motor and check for burnt contacts.
__________________
  #5 (permalink)
Old 10-22-2007, 09:03 PM
Junior Member
Default
I found burn contacts inside the switch mtr, coul it be the problem?
  #6 (permalink)
Old 10-22-2007, 09:08 PM
Junior Member
Default
here are pics
  #7 (permalink)
Old 10-23-2007, 03:02 AM
Senior Expert
APP Volunteer
Default
Very rare these switches go bad unless oil gets in them. Verify with meter good ohms when activated; ie. less than 1 ohm.
Check timer also.
__________________
  #8 (permalink)
Old 10-24-2007, 09:45 PM
Junior Member
OK guys. For your files I changed the swicht mtr and the washer works great again, the timer is ok, thank you for all your help
  #9 (permalink)
Old 10-28-2007, 04:49 PM
rmfield rmfield is offline
Junior Member
rmfield is on a distinguished road
Default Same problem with GE top loader
Moved to new post
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer/refrigeratornot cooling, motor running with clicking sound intermittent counterbob20 Refrigerator & Freezer Repair 2 10-07-2007 01:23 PM
Belt off motor dbilloni Dryer Repair 1 09-30-2007 02:20 PM
intermittent Cooling GE bobp Refrigerator & Freezer Repair 0 08-14-2007 06:58 PM
Dryer motor R&R Pete Dryer Repair 0 08-14-2007 01:38 PM
Motor capacitor hot dualsport Dishwasher Repair 0 08-14-2007 12:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
