Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Washer not draining water...HELP!!! (http://forum.appliancepartspros.com/washer-repair/181787-washer-not-draining-water-help.html)
melga72 03-02-2011 12:55 PM
:confused: I have an affinity front loader washing machine by frigidaire. It has recently begun to not completely drain the water after the spin cycle. My hubby took it apart on Sunday and cleaned out the hoses. It worked fine through 2 loads of laundry, then today it completely stopped working. Today it made a noise like there was air in the line and it didn't complete the spin cycle, no draining at all! This is so frustrating! Could someone tell me please what they think the problem might be and how easy of a repair is it, and what kind of part we might need to replace? My husband is very handy and I believe he could fix it if we just knew where to start. Thank you!
Gene 03-02-2011 06:03 PM
Did it show any error codes?
If it did not then perform the Diagnostic test as instructed in the Tech sheet and post the results.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE LTF6000ES0 Frigidaire/washer | AppliancePartsPros.com
mseverson 10-07-2011 01:11 PM
Did you get it fixed? Let me know what you did.
rich2012jag 01-14-2012 11:23 AM
Did cleaning the hoses include cleaning the filter? If the filter is clogged, the pump will not drain the water properly and the washer will not spin.
