Discuss
Grounding Control Board/
 in
Washer Repair
I have a Maytag MAVT546EWW washer. A common problem is the control board going out due to surges because it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Grounding Control Board/
  #1 (permalink)
Old 03-01-2011, 05:45 AM
Junior Member
tavarich7 is on a distinguished road
Default Grounding Control Board/
Model Number: MAVT546EWW   Brand: Maytag   Age: 1 - 5 years
I have a Maytag MAVT546EWW washer. A common problem is the control board going out due to surges because it is not grounded. Is there a proper way that it can be grounded? I'm not worried about voiding a warranty, but I also know that others who may still be under warranty may want to ground their machines.
Related Models
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
  #2 (permalink)
Old 03-01-2011, 09:41 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
I always recommend a surge protector for the appliances that have expensive boards. don't go with those cheap extension cord type; But you can find a decent unit that plugs directly into the outlet, and the applisnce plugs into it. Behind a refrigerator, it doesn't require much more space than what you probably already have for your water connections. It should be rated at least for 75 Joules.
If you consider going with this kind of protection, and you have other appliances to protedt (like your expansive TVs; computers; microwave ovens; etc.) you might even consider contacting your electrician, who can install whole-house surge protection at a reasonable cost.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Control Board or Control Panel which to replace? mavantix Dishwasher Repair 7 07-31-2012 06:54 PM
High voltage surge damaged the control board,replaced board,compressor still not runn shillion Refrigerator & Freezer Repair 0 11-16-2010 01:18 AM
Control Board or Control Panel? bbq.phil Oven Repair (including Ranges and Cooktops) 0 07-22-2010 06:01 PM
No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board hddman Oven Repair (including Ranges and Cooktops) 0 04-26-2010 12:09 PM
Grounding Wires Ge Refrigerator MGRINZ Refrigerator & Freezer Repair 0 02-02-2010 06:14 PM
